Hi all,
I’ve owned my R33 for 9 months now, and I couldn’t be happier :) There’s still work to be done though.
My aim is to have a strong, reliable street car with between 180-200rwkw. I hope to visit the track once or twice to test out the limits of the car in a safe environment (and probably do some driver training courses too), but going to the track won’t be a regular thing- not in this car anyway :P
Mods / parts replaced since I bought the car:
-Turbo-back exhaust with hi-flow cat
-Apexi pod filter (with enclosure coming, once I finally finish it)
-Project Mu Street Sports pads, front and rear
-Front and Rear strut braces
-Front mount intercooler
-Braded brake lines
-Nissan water pump
-Greddy Heavy duty timing belt
-Spark plugs (the details escape me but they are meant to be good, properly gaped etc)
Engine is an unopened RB25DET with around 86 000kms on it (had a genuine and verified 77 000kms on it when I bought it). Currently, the car runs well, never missed a beat. It is running a little rich, which I expect is due to all of the airflow changes that have happened.
So, some questions for the SAU community:
*Am I missing any supporting mods for my aims?
*Are there any other parts/items that should be replaced ‘just to be on the safe side’?
*I’m aware that I’ll need something in the ECU department to solve the running rich issue, and to make the most out of the other mods. What options do I have for around $500 (plus the required dyno time / tuning)?
*Any other power-related mods I should consider?
*What are some good, fairly inexpensive suspension upgrade options?
Thanks in advance
this has been asked id say 500 times in forced induction
there are litterally pages of your style of question and plently of guides etc
you should read over those it tells you everything and lots of in depth info
all you need is a piggyback (safc, emanage, powerfc) and a boost controller (bleed valve, hks evc, blitz sbc, apexi avcr)
I should mention I've done some searches and am aware of the existence of a number of guides, which I've read :) It's been good reading, but I haven't had all of my questions answered.
I was of two minds to post this, but I thought I would anyway since things can change over time. Just wanted to see what the 'up-to-date' recommendations were for this kind of thing.
Thanks for your suggestion. The PowerFC is a bit outside my budget, I was considering the Emange Blue with Fuel/Ignition control though.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
