Hi Guys,
I have a 1997 RS4 Stagea with 4 speed Auto. I have got a problem that when I cruise at 70km/hr or above the car seems to pulse. It does not do it when accelerating or when crusiing below 70.
I have changed fuel filter, plugs and had checked the coil packs for resistance values and all seem ok. I done this as the fault seem to act like a miss fire. The car has been checked on a diagnostic tested and all fuel and engine management appear to be ok.
I had the auto box replaced and I am now wondering if the electrics / sensors on the auto box are causing the problem.
Can anyone offer any advice or has anyone experinced a similar problem.
My email is [email protected] and contact number is 0423 474 985
Cheers
Paul
https://www.sau.com.au/forums/topic/204709-autobox-problemmaybehelp/
There is some Auto diagnostic information on this page http://www.skylinesaustralia.com/forums/St...ar-t203136.html , its for the R34, but the 4AT diagnostic may work.
Also, run the ECU diagnostic, if you havnt already.
But my first guess would be coil packs, even though they check alright, they are famous for leaking spark to earth around the age of yours.
Where are you located ? maybe someone can recommend a skyline expert in the area, or someone can lend you a set of coil packs. If they are at fault, best option is to get Splitfires, which is what most RB's need to do eventually.
Bad Air flow meter connection? doubtful.
Hi thankyou for the advice. I have heard that the coil packs are famous for leaking. I am in Perth so if anyone has a spare set of coil packs for me to try I would be very interested. They did look good but I guess they only need a slightest crack to cause a leak, if it is them it does explain the feeling when driving of a misfire. If it was the coil packs would this happend at all speeds as my problem only seems to happen once I get over 70kmh.
I have also cleaned the air filter (k&n) but I will check air box.
Thanks again
Paul
I forgot to say that
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
