hi everyone,
i was wondering if anyone has bought or all ready got one of those just jap RB20 split dump/front pipe on their car.
Im planning to get one and a high flow cat they got on sale for $160. Just want to know how good is the craftmanship,
performance wise- any difference ? does it turn purple afterwards and the metal turn out crappy etc etc.
iam not sure if i should buy one from just jap or the group buy that is on at the moment.
any information will help guys so leave a reply :D
https://www.sau.com.au/forums/topic/204729-just-jap-split-dumpfront-pipe/
I got one (its not on an RB20, its on an RB25). I bought it as part of a full turbo-back exhaust system from Just jap, with the high-flow cat.
Performance-wise, i noticed a BIG difference to be honest, especially up high in the rev-range. Definitely lets the turbo breath a bit better. Its still going fine for me (haven't had a look to see if its gone purple though), and the craftsmanship seemed pretty decent when i inspected it after purchase. I fitted it myself with a couple of mates (at 2 am in a shopping car park LOL) and had a tiny bit of trouble bolting the dump up. Just make sure u use the couple of the gaskets that are provided, as well as the stock metal one to make sure theres no leaks - otherwise it may come a bit short.
Heaps of people will argue for/against the split till the cows come home. My opinion is that the split arrangement should theoretically improve transient response: although the wastegate & turbine gases do ultimately meet anyway where the split pipes merge into the front pipe, the initial twin piping should help to keep the gas streams separate. This in turn reduces turbulence directly adjacent to the turbine and allows your turbo to work that little bit easier.
In any case, its definitely an upgrade over the stock item you've got.
hi everyone,
Edited by -33-
I have one on my R33 25-t, performance wise like the others have said it feels like a big improvement up high.
Only issues i came across was one of the bottom bolts is tricky to do up because of the immediate bend of the dump pipe. It IS possible tho, you just need to use your head :cheers:
And the turbo water feed is kinda "leant" on by the dump pipe and manifold heat shield.
After 1st installing it i got mass amounts of white smoke burning off it, that went away pretty quick. When a sexy gold colour, then obviously got damp, as it will, and got a purple tinge to it.
Whoe cares tho. You cant really see it with a stock turbo and heat shield.
i got one with CATCO 3'inch high flow cat, with Trust/Greddy 3'inch front dump pipe, 3'inch Greddy/Trust PEII extreme with some brand split dump pipe from the turbo... and i tell ya the improvement is excellent!
Just fitted one to my r33 last night, along with a de-cat pipe. The quality is pretty damn good and I managed to fit it with a friend without any major hassles (nothing but hand-tools) in about 3 hours. Haven't had a chance to take it for a good drive yet, but I assume it'll have my car running even more lean than before.
So what did you guys do with the water line?
Im looking at putting one of these on when i upgrade my turbo, just wondering if anyone has thought of tapping into the external dump pipe from the wastegate and putting and external wastegte in there and removing the internal flapper, will this give better boost control?
^^^ Well there's heaps of split dump pipes out there that have an open wastegate pipe (i.e. not welded back into the front pipe like an ordinary split). It probably would help surge and give better exhaust flow as well. Have a look and see if you can find anyone running one of those. Although if you are getting an aftermarket turbo and are thinking of that sort of setup, why not just get an external wastegate?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
