  • Replies 78
Posted Images
f**k yeh, where from? got a website?
nah dont have a website but its from a local car shop - Car Bitz in Syndal, Vic
I wont know how good they are until i try it when tracking the car :) (but so far the water and oil temp work fine - same with boost - but its the oil pressure that i keep my eye on all the time)
they sell RDA's too now - similar price to the group buys :D
they look good Ian, are they 52mm or 60mm? as i want a dual gauge pillar, the ones form autobarn are like $170 and 60mm...but i found autometer ones that suit either 52mm and 60mm gauge..i love the cobalt series
where do you buy that pod from? looks so nice
Thise triple gauge pod things in the first two pics look good... who sells them?
But would they still be a defect as you cant have anything over the dash line?
swear i saw them on greenline a couple of weeks ago, give that a check
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
