  • Replies 52
I'll take absolutely anything you can find this weekend - at the moment the best I can come up with is driving up and down old pac all day - I need to get my 500klm up on the new motor.
We've checked all 3 track's websites and run EC and WP to confirm - nothing is on this weekend and next weekend is looking bad too.
https://www.sau.com.au/forums/topic/204939-this-weekend/#findComment-3630926
There is stuff on next weekend! :P My cruise would rack up your kms :no:
https://www.sau.com.au/forums/topic/204939-this-weekend/#findComment-3630933
Duncan,
If you like, I am more than happy to go out of my way, give up what I had planned to help you get those km's up...just gimmie the keys! (dont worry, I'll be covered!! :no: )
seriously though, sat arvo I'll head up with ya, i'll give you a buzz :P
https://www.sau.com.au/forums/topic/204939-this-weekend/#findComment-3630963
lol!!
Ryan grab a few roadies mate!! it'll be fun..I mean..umm...a nice casual drive.... cough :no:
Aww come on duncan, I helped you and Kel unload and load the GTAAAAAAAAAAAH at the SnS!!
https://www.sau.com.au/forums/topic/204939-this-weekend/#findComment-3631040
lol!!
Hahaha, that was scary - right rear tyre stayed on the ramps with only 1" of it's tread, and the old Navara kept rolling off because even though the handbrake was on, the rear wheels were off the ground due to the weight transfer on the trailer.
https://www.sau.com.au/forums/topic/204939-this-weekend/#findComment-3631445
old navara? its an 88 only 1 year older than a gtr :) she does have 350000klm on the clock though
and that wasn't even close to falling off the ramps. i'd know it fell off the ramps one day when I was trying to drive it up onto the trailer, on a steep uphill, in the rain. all 4 wheels spun, slid sideways, fell off. really capped off the day since the reason i was putting it on the trailer was I'd just been done for driving unregistered car
https://www.sau.com.au/forums/topic/204939-this-weekend/#findComment-3633600
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
