  • Replies 55
yeah it has been done a fair bit up here, so it must be possible.....they look abit big and roller skate-ish unless you have it tucking some serious rim!
I'd like to see 22s on an RX7, got any pics(?), I reckon that would look rediculous, they are too squat and sleek for something that big....20s are even a bit over the top!!!
i asked 4 comments bout if they will farking fit not wank factors and shyt. keep ur farking shyt 2 urself u dumb farks. u tite asses cant afford 20s and 22s so stick to ur 18s then. to every1 else thanks 4 the comments.close this thread if ppl wanna be heroes pm me plz
settle dude, it's public forum, people are at liberty to give opinions, no need to try get all high and mighty, I was saying that it is possible, not ragging on you.
can't afford 22s, yeah, sorry been there, done that, but yeah I'll stick to my smaller wheels, they'd out price your 22s anyway!!!!
ppl that say no way it wont fit, i wonder if theyve actually tried, we put 22s on the back of my mates r33 and s15 in about 15 mins, the rear guards were just lipped thats it ( which was done ages ago anyway)
agreed put 22s on the front too that would look tough.
yeah wateva got 20's on mine and got 24's on my hilux so yeah.... you sound like the guy who wants to be the hero
I was told 20's wouldnt fit my MR2 but i showed them. Had to buy coilovers and do other things but i got them on there with no scrubs from anywhere.
Go 22's man. Some wise man once said "get the rims you like and build your car around them", right Anthony(2 GUP)?
oh so true
Go for it mate. Don't worry what others say, at the end of the day its your car and you do it up to your own tastes.
As for the 22's they will fit up not a problem as long as the offset is right and you stretch on some slightly undersized tyres on.
And also it would be wise to get coilovers as they have smaller dimension than stock, and are stiffer so the car doesn't bounce and scrub.
Tai
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
