hi all...got a S2 R33 and wanting to put on an exhaust system on my car....
what is the best type/setup for the liners..? how many inch wide pipes etc....
i also want it to be on like a switch or something so that i can have it on silent from time to time and be able to switch it to loud jus by flicking a switch....
can u let me know the systems that have this type of capability or what i should be looking for in order to have this type of setup...
Cheers
Matt
https://www.sau.com.au/forums/topic/205370-which-exhaust-system/
i think this is what u are looking for
http://www.importscene.com.au/prod466.htm
As above...The Jp systems are the best bet. They come with a Db rating so you have some confidence that you "probably" wont get defected. Switch-Apexi do a valve that can restrict the noise but i dont know that i'd want that. The quality systems sound fine anyway. Size-3 inch is fine for a "line" under 400KW
oh GL with it. lol
nice....i lol at ur 'GL with it'
see as my av says....now ur a big man!
i have been recommender a HKS Super Dragger....any thoughts?
pro's and con's experiences.....let me know...
The HKS Super Dragger is very old and is no longer made.
Your best bet is to get a quiet street system, like the Kakimoto Regu 06&R.
I have seen a lot of different exhaust systems out of Japan and in terms of build quality, the Kakimoto is up there as one of the best.
Hey mate i just installed myself yesturday the Kakimoto Regu 06&R exhaust. I also used a just jap front pipe and cat.
Sounds quite on idle but then when you put your foot into it sounds great!! not a drone, not farting but a reali nice sound. Was reali suprised how nice it did sound. And for the cost it was quite good. Looked well made etc etc
Wouldnt change it for anything :(
Buy a decent Japanese made system, turbo back. Dont go cheap, the drone will annoy you.
+1
i like the super dragger also
but like Blitz said, no longer in production
looks sexy as
does anyone know what the JJR Hyperflow exhausts are like?
Droney... :) Actually that is what I had and I sold it as I could not stand the drone after a while. They are cheap and give good power, but you really NEED an extra oval resonator in there instead of that canon or weld one in the middle of the exhaust!
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
