I have posted a thread last week concerning a fault I have with my 97 RS4 4speed auto were the car seems the pulse when cruising at 70k's or over (the car is soomth as below 70kph). I have replaced plugs, fuel filters, had injectors cleaned, gearbox flushed and new oil put in. I was thinking it was coil packs so have some Splitfires on order.
Any way I was under the car at the weekend and I have noticed my rear tyres are like racing slicks on about a 1/3 on the inside of the tyre. This has only happened in a month after I have had a replacement gearbox. This got me wondering if the Stageas suffer with diff lock...were the diffs get wound up..or somthing like that. Is this possible to happen on a AWD?
If it does I am pretty sure this would destroy the tyres in such a short space of time and explained the jerky drive.
Can anyone help me?
Cheers
Bakes70
https://www.sau.com.au/forums/topic/205465-do-stageas-suffer-from-diff-lock/
Can anyone help me?
Cheers
Bakes70
Do you have different tyre diameters front and rear? To upset the ATTESA it usually requires more than just brand new tyres on the front and worn out ones on the rear.
The inside tyre wear is usually due to excessive negative camber and/or excessive toe out.
Cheers
Gary
Gary,
Thanks for that mate. All four tyres are 215/50 ZR 17.
I have booked the car in to have the wheel alinment checked and that the wheels are all balanced correctly?
I am just trying to eliminate factores that could be causinging this problem. I am beginning to worry that it might be a gearbox problem. The car did not have this problem before I had a replacement box fitted. It could be coincidence and the coil packs have given up the ghost or it could be the gear box or a problem with a diff.
Do you have any ideas?
Cheers
Paul
Don't be too surprised about worn tyres front and rear causing pulsing problems. I've had huge problems with this in the past. It all started when my front tyres were very worn on the inside (bad alignment and excessive camber, still runs a little to much but they're wearing much better now) so I got new tyres on the front and left the rears as they still had plenty of tread left.
But the car didn't like this one bit, after about 60kmph it would jump and pulse around. After trying different tyre pressures I swapped the front and back around and bingo fixed the problem but then as the fronts (old rears) wore out I put new tyres on the front (there wasn't much time in between the first and second set of tyres) so essintially I had 4 new tyres of the same size (or so I thought and it was according to the lables on the sides of the tyres).
Although I had the same size tyres they were different brands, and the same problem came back so I tried the swap trick again. But as I was swapping the tyres around I put them side by side and you could actually see a difference, not a huge one but it was there, I guess just different ways of making the tyres (there would have been no more than a month - month 1/2 betweeen the 2 sets). And it fixed the problem once again and the tyres are wearing fine now and no more shudder or pulsing.
So my suggestion would be to try swapping your tyres around when you get the alignment done and see how you go!!!
Thankyou for this info. I will try this. I will be gutted if this is all my problem is as I have spent a few dollars trying to troubleshoot fault. Did you get the problem at all speeds or once you went over a certain speed, as my car does not start to pulse/shudder until I get to 70kph or above.
I will let you know how I get on.
Cheers
bakes70
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
