Condition: Very good
Price: $150.00 Pickup only PRICE DROP $90.00
To Fit: R32 GTR
Contact: 0417 841 024 or PM me
Comments: The Springs were off my gtr when i changed to coilovers. They are slightly lowered compared to standard but still very practical for everyday use, as shown in the picture. They are also slightly stiffer for more positive handling and control of the car. I feel very little difference between these and the Tein Super-Streets which are now on the car.
I also have for sale a Brand new GTR mag:
The GT-R Special mag by autoworks no.22. This is a special edition mag with a very interesting article about how to upgrade your R32 gtr mechanically into a 34GTR including brakes, gbox, attessa, diff, driveshaft etc... This includes some awesome pics to help out with any problem areas for the conversion. A great mag filled with great pics.. Also comes with a cover so mag is in brand new condition. $30.00 plus postage SOLD
Edited by zandi2000
https://www.sau.com.au/forums/topic/205489-32gtr-sports-shocks-springs-90-sold/
Do you know how old the springs are and how much lower than standard?
The springs would be a good 5-6 years old i reckon but still working perfectly the paint has come off them a tiny bit, the ride is about an inch lower then standard, i can put some pics up of my car with them if you want..
also
are they standard gtr shocks
any leaks??
Ride comfort is awesome. i used to drive all day with them without so much as an ache or pain. I believe they are standard shocks yes with no leaks at all!. They have no adjustment but they are silver with the GTR logo on it. The ride is compliant and balanced but not jarring over bumps, i think because its a progressive spring you don't tend to feel the smaller bumps. I loved this suspension but it lacked the adjustments i wanted for trackwork.. great for street use with occasional sprited driving though!
Edited by zandi2000
hey mate do the come with the springs and shocks? what brand of springs are they?
how much posted to 5211?
cheers
Edited by Turbz_13
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
