Item: Series 1 R33 RB25DET 130,000kms
Price: $1000ono head is off so will require new head gasket and manifold gaskets
Location: Southside of Brisbane, It is sitting on a pallet to be shipped if needed
Contact: PM
Comments:
Decided to do my RB30DET Conversion
Complete long motor including Turbo/Plenum/Split dump
Always run clean and looked after blew no smoke
Fueled with BP Ultimate or Shell V-Power Racing - Always!
Serviced every 5K with Royal Purple and new Oil filter
Motor recently had a standard 100K service
Including:
New Genuine Water pump and HKS Timing belt
New Exhaust Manifold studs nuts and gasket
Good condition coil packs and NGK Iridiums
Turbo has got next to no shaft play and seems in great condition
Effortless 190rwkw with the power fc tuned running 12psi (never run more than 12psi)
Considering breaking it down: EOI Pm me
Head $580
Short Motor $280 Perfect working order when removed
Coil packs (awesome Condition) with loom $100
R33 Turbo/Mani/Split Dump (manifold has some sort of black heat coating and new studs looks schmick) $520
Plenum Throttle Body assembly $50
Stock Air Box $150
Stock cooler pipes $50
Aircon $120
Powersteering pump $120
Starter Motor $??
R32 Loom $??
R32 RB25DE NA Computer $100
R33 RB25DET Computer $140
R33 Air Flow Meter (AFM) $120
Carbon Canister $20
Near New (500kms) HKS Timing belt $80
Near New Genuine Nissan Water Pump $40
Brand new Genuine NISMO Short shifter $??
Brand new Genuine Nissan Timing belt $90
Can deliver to Goldcoast / Ipswich / Northside Brisbane for Beer (whole motor only)
Edited by dano4127
https://www.sau.com.au/forums/topic/205620-series-1-r33-rb25det-brisbane/
I have ECU's, Did you want R32 RB25DE or R33 RB25DET?
Want to sell the turbo included with the motor
Pm me if your interested
Edited by dano4127
how much would u charge on the R33 RB25det ecu
BUMP - Still here! Considering breaking it down if I can get rid of it quickly
Open to serious offers :banana:
Edited by dano4127
interested in the head as long as its in good nick, no offence but ure asking price is way too high for me, if ure willing to lower it we may be able to come to some arrangement, cheers Damo
Nismo Short Shifter? how much? is it new or used and does it come with all the bits to fit it to a R33 GTST?? thanks PM me with how much sent via express post to gold coast.
Edited by SLYDA
hey, im interested in the head. is it in good condition after blowing the gasket. and does it come complete. cams valves covers etc. if so i will pick it up in the next few days. where bouts in brissy are you. im on the gold coast if we maybe could meet half way
let me know
cheers
  • 1 month later...
  • 6 years later...
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
