WTF are you talking about...
are you just unhappy that you got drilled on there?
QUOTE(kietz0007 @ Feb 11 2008, 11:55 PM) *
lol dats preety daring swerving ur car into another lol i woudlnt do dat shit to my car ahahha
QUOTE(BillyE @ Feb 11 2008, 10:26 PM) *
really? you wouldnt????
wow i thought most people would
why wouldnt u?
QUOTE(kietz0007 @ Feb 11 2008, 11:58 PM) *
and why would YOU?
QUOTE(MR 1JZ @ Feb 12 2008, 8:09 AM) *
the point bill is trying to make is that you do not have the mental capabilities to post with the rest of society on an internet forum, so for everyones sake please stop...
lol seems like you come from NS.com and you don't know how to quote properly. now used the edit button
Edited by ztuned
  • Replies 51
Posted Images
http://blitsbodykits.com.au/ << they do 4door side skirts were $125 each
http://www.uniqueautosports.com/pricelists...er33styling.htm << GTR STYLE SIDE SKIRTS FOR SKYLINE R33 GTS-T 4 DOOR PRICE: $450.00 PAIR
there is a Type M 4 door body kit also that looks sexc as
4door_sleeper: let me know where you got the side skirts n rear pods from as i maybe gettin a 4 door to putt around in, cheers
aww thanks :thumbsup:
+1........warped sense of humour but you're a legend steve
Pfffft NS.com :(:P
Shy_s6 if you don't like what people post on a open forum, You know where to go........... :nyaanyaa:
i was just pointing out that all forums are as bad as each other :P ive been around for a lil bit so i just found it amusing when kiet was saying i dont know 'shitz' about stuff, so was just stirring him up :blush:
madaz: cheers for the links!
Dunno about them all being as bad as each other, I can se a distictive difference to "here" and "there"!! Yeh you have been around a while and put in handy comments, Just remember if you stir too much, here and there will definatly be the same and i'm pretty sure theres quite a few people here that don't want that.....lol....... :nyaanyaa:
Edited by Deluxe
dont diss sopranos lol...
Back to the f**king topic...
The cars involved were a Nissan Maxmima 1992, Subaru Forester 1984 and a Toyota Camry 1993. (for all u paint-sticks know.)
And the speeding was probably caused by 2 soccer mums driving the respected vehicles to beat eachother to a futon sale, the Nissan Maxima (boldy credited as a Nissan Skyline) driven by an 18yo bystander, was a mere spectator to the incident, and because he had a nismo sticker on the rear windscreen of the car; suffered.
When are they going to start showing pictures with these articles of street racing. Even if it voids censorship.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
