ive got ca18det injectors with the ballast resistor and a z32 afm and a r33 turbo with bosch 040 fuel pump....will my apexi safely support these mod's??
please speak from experience!!!
Edited by allthewaytotheskyline
does any1 know???
what size are ca18det injectors. with a safc you dont want to have to take out too much fuel otherwise it indirectly stuffs with your timing. and yes, a safc will support a z32 afm. you just set it up so the safc knows its getting a signal from a z32 and sending it to a r32 gtst ecu.
the injectors are 370cc...enough for 200rwkw???
i thought stock R33 GTST injectors were 370cc? and my power FC reported 100% injector duty off 14PSI boost, stock turbo, intercooler etc.. with the base FC map.. so i doubt they will support up to 200RWKW.
safc will run the 370cc injectors, it will run the Z32 afm, it will run a fuel pressure regulator and a 040 fuel pump, it'll even run with a highflow turbo. speaking from experience. daily driver. 190rwkw. upgradding to PowerFc as soon as I book it in.
a sitc would help for the ignition timing adjustments.... BUT if you have a R32 Id personally get a remap (contact username: Yoshi) and still use the safc for minor corrections.
wats a sitc??? and how do i get incontact with yoshi??? is he located in sydney??
also how come your upgrading to a power fc if your apexi safc is doing a "good" job?? or isnt it!
sitc is an apexi Super ignition Timing Controller
adjusts the ignition timing, like the safc adjusts the air;fuel ratio
google is your friend
Ive been using safc/sitc for 2yrs. thought its time to "trial" a PowerFc with my auto box
fact is a full aftermarket ecu will always be a better choice than a piggyback.
Yoshi does remaps, have no idea where he is. pm him.
yes - my safc has done an awesome job. just noticed tho that you are talking about a SAFC1. bugger that, get the SAFCII or the SAFC Neo.
ive got safc1 already installed so im gonna have to put up with it...where did you buy ur sitc from?? and what was it worth???
As I mentioned in a PM.
Using a Z32 with the SAFC is 100% pointless as the SAFC bends the voltage back to what it would have been with the stock afm.
As a result if the stock afm were maxed out yet the Z32 is outputting say 4volts. The safc will increase the voltage back to the maxed 5.1volts so the ecu against see's 5.1volts as it did with the stock afm.
Stick with the stock afm, stock injectors and a nismo fpr in your case.
IF you were to have the ecu remapped with a high flow then do consider the Z32 and ca18det or gtr injectors.
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
