Hi All,
I have a RB30/25 Motor for sale (Head to sump)
Series 2 Block
Port and Polished
VVT Removed
Hks Cam gears (Inlet and Exhaust)
Hks Cams (264's on either side)
GTR valve springs
Dayco Timimg Belt
Denso 770s injectors
HKS Fuel Rail
Splitfire Coil Packs
Forged bottom end
Hypertech Ceramic coated pistons with Hastings rings
bored 20thou
Stud Kit
Eagle H-Beam Rods
Hi Energy 8ltr sump
Balanced and Blue Printed
N1 Oil pump
N1 Water Pump
Honed, Decked
New Bearing and Gaskets
Much more but I can't think of it now.
Any questions leave them here or call me on 0401 670 923
Im asking for $5000ono
Comes with no Manifolds or Turbo as I will be putting them on my engine.
I'm Located in Clayton
https://www.sau.com.au/forums/topic/206059-fs-rb3025-motor/
is the engine set up for single or twin turbo????? also would u be interested in shipping to sydney??? my father works for toll..... if i can organise for toll to ship it up here would u be able to get it to the toll depot??? ill be able to provide the address for u to get to the depot once my father has cleared it with his work and gotten a final price and shit..... all u would need to do is get the engine to the shipping yard as they do not do pickups for these sort of things.... my dad said
Edited by punisher6942
https://www.sau.com.au/forums/topic/206059-fs-rb3025-motor/#findComment-3652846
The guy I bought it off told me it was built by RE. The motor has been stripped down and all the goodies are in it. I even have cam boxes etc for it. Im just going by what he told me. It might have even just been tuned by RE and bottom end built somewhere else.
Ill try find some other history on it but thats as far as I know about the motor
https://www.sau.com.au/forums/topic/206059-fs-rb3025-motor/#findComment-3658534
dude have u got any pics of the motor u can post up or email to me??? email me at [email protected] with all the details of the engine im VERY interested...... i may even be tempted to come down to melbourne to have a look at the motor also is the motor able to be started at all???? i wouldnt mind hearing it run if i do come down for a look......... get back to me asap plz
https://www.sau.com.au/forums/topic/206059-fs-rb3025-motor/#findComment-3661986
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
