Hey guys,
I've been MIA for friikkken ages.. pretty much the time wasted was wasted on playing COD on 360.
I am selling my Vitara and add the proceeds to support my running of the bulls trip in July.. after BARELY 3 months of having it, I'm selling everything and it's ALL GOT TO GO! SALE SALE SALE! Like persian rugs!
If you know anyone that digs Vitara's or wants a full tank of petters to last around 550kms, send them this link here.
Anyway, nothing much has been happening. After being dogged by work, I found another contract job to keep the funds rolling in whcih is also to end by the end of the month, I have tried looking for permanent jobs within private sector, but no response. I'm so lonely. But I'll keep trucking!
I see soo many skylines around, and have yet to see mine - thank god! Has anyone seen it?
Okedokee! Well, I'll be online more because my contract ends soon and now I'm just bludging.
Edited by S T A R 3 3
https://www.sau.com.au/forums/topic/206116-im-back/
haha, was expecting it to be a "Selling car and going back to a skyline"
My mum is looking for a new car, i'll ask her tomorrow and post up here.
(if my mum buys this car its 2 cars i've sold for you haha)
Edited by Baconer
https://www.sau.com.au/forums/topic/206116-im-back/#findComment-3649613
Cheers guys! Yeah, pretty happy with it.. not too sure what i want to do with it.. alot of people said keep it original, which it is atm.. or do an engine conversion. 2JZGE, perhaps?
Would anyone have a spare stereo mounting bracket laying around?
https://www.sau.com.au/forums/topic/206116-im-back/#findComment-3672234
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
