Hi Guys,
I just put the stock oil pressure sender back on because my Greddy one broke. So now iam use the stock gauge on the cluster, When i hit boost it use to jump stright up to 8 kg/cm2, Now
it goes up slower and reaches just under 7 kg/cm2. Or is it fine and the stock gauge is just reading not as accriate.
Any feed back would be great. THANKS.
https://www.sau.com.au/forums/topic/206182-oil-pressure/
Hi Guys,
The stock gauges are not very good. They are much slower to react and are not very accurate. I recently did the reverse. My stock sensor was hardly reading at all at idle and often would drop to zero. Oil light would come on as well. I checked and there was plenty of oil and it was still getting to the head even though gauge was showing zero pressure. Then it would jump straight up to 2kg/cm. Would often fluctuate between 0 and 2. It only happened when engine was hot. It was reading normally at all other rpm ranges and temperatures so I wasn't too concerned.
I put an HKS mech gauge on and it was much faster to react and never dropped to zero..Concluded that the stock sensor was buggered.
Hope this helps
https://www.sau.com.au/forums/topic/206182-oil-pressure/#findComment-3649090
Workshop manual states that when hot for an RB25DET you should achive the following:
Idle: 1.1 kg/cm2
2000rpm 3.5 kg/cm2
6000rpm 5.6 kg/cm2
Odly, the RB26DETT should be higher at idle, and lower at revs (slightly)
Refer to attachment I have uploaded for relevant Oil pressure readings.
Skyline_Oil_Pressure.pdf
https://www.sau.com.au/forums/topic/206182-oil-pressure/#findComment-3649150
Your guage probably isn't accurate. Wouldn't rule out other possibilites though. Did it have normal readings with the Greddy sender?
Yea with the greddy it was normal and it would go all the way up to 8. Then it broke.
https://www.sau.com.au/forums/topic/206182-oil-pressure/#findComment-3649287
I heard that the stock gauges are not the best, I need to go and get another afther market one asp.
Ill most likely get my car dyno tuned in the next couple of weeks and they be able to tell me if my oil pressure correct.
https://www.sau.com.au/forums/topic/206182-oil-pressure/#findComment-3649300
Wow, well mine definitely sits at alot higher then 1.1kg/cm2 at idle. I know not all idles will be the same, but its always on 2. Nearly double seems a big gap for a faulty sender. Mines a NEO, which could change things
yeah my neo reads pretty high aswell, at idle once warm it will sit right on 4, which is almost double anyother r33 i have seen. I havent put a mechanical gauge on it yet, but those stock gauges seem to lie a fair bit
https://www.sau.com.au/forums/topic/206182-oil-pressure/#findComment-3650002
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
