I'm not a F#*kwit mate i know where offsets are
usually printed and there not there....
As for these wheels fitting perfectly on both those
toyotas and skylines...... They do cos i'v had them on both!
Edited by JDMS15
https://www.sau.com.au/forums/topic/206221-sold/#findComment-3650307
Geez buddy calm down.
Well, it doesn't help when you say Toyotas. How F***ing open is that.
What skyline aswell?
If there are missing details, you gota help with as much details you know from personal use.
https://www.sau.com.au/forums/topic/206221-sold/#findComment-3650334
hey mate whereabouts are you?
Any pics of the gutter rash? i will be painting the centres black so thats no issue, but wouldnt mind seeing the damage you mentioned. Have you had them on a balancer to see they run straight? At a tyre joint? they could spin them for $20 for you and let you know if they are bent or not.
https://www.sau.com.au/forums/topic/206221-sold/#findComment-3673632
Hay bud i'm in vic,
And as for the wheels runnin straight yeah there fine
they used to be our dyno rims at work,
As for the gutter rash it's fairly extensive but nothin
that can't be fixed for fairly cheap!
https://www.sau.com.au/forums/topic/206221-sold/#findComment-3696960
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
