  • Replies 132
Hey! did you guys know you can modify these cars!
I thought it was like real life where you've gotta race with a stocker!
Down to 1.12.5 now I'm using cheater turbo and cheater tyres.
So the record is still 1.10.696 for wheetbix?
Well I Finally got a Nissan Car a did 5 laps today... best time of 1:32.222
Car:
R34 GTR V-spec II (R34,J)
Mods:
Full Custom Gear Box
Racing Fly Wheel
Carbon Drive Shaft
Tripple Plate Clutch
Racing Zorst and Filters
Sports Rom
Custom LSD
Port and Polish
Stage 1 turbo
BHP 428
Cost approx 100,000cr
Now if we look at the cost of this Penzoil GTR we can note that it is approx 7.5 time the cost of my car... 7.5 times the best time I have seen here is 7 and a half mins;) !!! :(:P:D Come on guys... how slow are ya!!! LOL :bahaha: :bahaha: :bahaha:
They will be my next investment...
you know when I played and finished GT I used to dream of owning a skyzer... then I played GT2 and Dad had one... which was worse... today I played GT3 and then jumped in my skyzer and took off up the road to work... Don't think I'll be able to afford the GTR that I'll have to buy when GT4 comes out!:(
