  • 1 year later...
  • Replies 47
Posted Images
sorry to dig an old thread, but people have been using these for a while so im after some info...
with the varex shut, and the gasses diverting through the muffler and out the small hole, does this provide too much of a restriction? and would this damage the engine?
if i installed my varex i would have it shut 99% of the time, and only really open it up on the track, but i dont want to risk damaging the engine if i drive around with it shut day to day.
my car is rb25det with 262rwkw. running a cheap china hot dog and cannon atm,
It will run fine shut, however I've been advised not to give it WOT / full boost when shut...mainly just for punting around in the city because it is quite restrictive (read: quieter than stock). The varex isn't really that loud when it's open...it's quite a nice exhaust note actually. Just get a middle muffler and you'll find you're only closing it when you see a police car in the vicinity.
I found the Varex to be fine shut right down when putting around town, otherwise I would leave it wide open.
As birds has mentioned, even wide open it is not particularly loud, and it definitely produces a nice note - much nicer than the Xforce cannon I had on previously. I certainly wouldn't put my foot down with the Varex closed down, or even partially closed down.
You may possibly lose a few KW into the bargain with the Varex - I didn't put mine on the dyno after the change, so that is only a guess on my part.
I should add that I got the oval twin pipe version, and not the cannon type.
I certainly didn't regret getting the Varex, didn't notice any actual power loss and loved the note it produced.
Originally I bought it for situations where I didn't want to attract attention, and Varex did a great job as far as that went.
Have replied to these threads previously but,
Compared to alot of the off the shelf products it does produce a good note, but you are paying the extra cost to have it
It does lower the kW output when shut, but it doesnt damage your engine running it shut on day to day driving as I've had mine for over a year not a problem at all, but if you want to put your foot down I'd recommend it open...
Depending on the car your running it off is to how loud the car is, as my friend has it on his 34 GTT and another on an RX7 and they are ear piercing when open...so don't count them out, they may not be a screamer pipe but they can be loud
I'm currently having mine changed from remote to in car switch to turn mine from Open > Half Closed > Closed, easy access if you are being tailed by cops
If you want it installed, I'd recommend contacting Auto Xcess in Nunawading, http://www.autoxcess.com.au/
Any questions feel free to PM me
I've been running a 3.5" in and single 3.5" out oval one of these for about 5 months now , and even wide open it would probably pass the 89/92 decibel or wtf the level is test.
I did the wire in myself and took power from the cigarette lighter with a small on/of rocker switch located next to the gearstick and the control box velcro'd down in front of the gearstick just under the ashtray so I can get at the fuse by taking the ashtray out if I need to check it .
It was a pita to put the wireing in as I had to remove the back seat ( friggen all of it) to get the wireing through (though others may know of a better way off doing this) I also had to drill a larger hole in the boot next to the spare to get the cable through as the damn plug on the cable wouldn't go through the hole that is already there (you could also cut the cable and re-attach it) , I just followed the factory loom and attached the cable to it with ties and crossed over to the centre console under the drivers seat , If you go this way don't forget to put the grommet for the hole in the boot over the cable before you feed the cable through. :down:
You could probably cowboy this though by running the cable underneath the car and comming up through the gearstick BUT it would be visible and as these things are not legal I figured that I would leave as few signs that it was actualy there as possible.
If you fiddle with it you can get it to open to just about anywhere you want, I run mine at about 70% open , it cuts out nearly all the mind numbing drone that a 3.5" system notoriously produces and as there is a bypass pipe you loose virtualy no flow loss just the noise, but it was a bit fiddly to do .
I have mine highset so the on muffler control is extremely difficult to see and given the basic quietness of the muffler I doubt anyone would bother to give it a good look anyway.
One other thing--a muffler shop I talked to told me they can jam so I guess it would be a good idea to fully open and close it fully a few times on a regular basis to make sure it dosen'r 'seat down' as it were.
Phew--and thats what I know about that :blink:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
