looking at a 180 that ive found and they have upgraded the engine which was a non turbo sr20 to a rb20 from a r32.
Is the RB20 a better engine than the SR2 DET or would i be better of buying a 180 with a stock turbo engine already in it?
any help appreciated.
https://www.sau.com.au/forums/topic/20643-sr20-det-vs-rb20/
does it still have LSD like the factory turbo cars. It would have to be 94+ model eh? if its got lsd then id get it especially if it has the updated interior. If you wanna go all out on mods then the rb20 is a more solid platform. If youre gunna go smallish mods id probably just get one with an sr20det. Also check how big the brakes are, i'd definatly want some decent stoppers on a car like that. If theyre the same size as the sr20de sils id be budgeting in a brake upgrade.
in the end its up to you. i'd try and use the fact that it was once an n/a, and your going to have to spend more on this one to spec it up, than to buy a normal sr20det one
https://www.sau.com.au/forums/topic/20643-sr20-det-vs-rb20/#findComment-432748
Hey Steve its dropping oil already :mad:
CS_180: All 180sx were turbo I believe, except some of the later (late96, 97+) models..
RB20DET and SR20DET are similar strength/outputwise, you wouldn't replace one with another (:P)
Just consider that it will likely need as Gary said, brakes, diff, (maybe gearbox) and engineering!
https://www.sau.com.au/forums/topic/20643-sr20-det-vs-rb20/#findComment-433561
Saying the SR cant handle the mods like an RB20 is a fairly broad statement which really doesnt hold any weight. The SR is just as good as the RB20 if not better, when theres Perth workshops turning out 700hp SR20 monsters then it makes you realise how good they are for a 2 litre, 4 cylinder.
And as meggala shows, putting one in a skyline results in enough engine bay room to mount an intercooler flat in front of the motor, which alot of jap guys have done in R32's. The SR is ALOT lighter than the RB20 (alloy vs iron), that picture alone should demonstrate that.
Red17
https://www.sau.com.au/forums/topic/20643-sr20-det-vs-rb20/#findComment-433920
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
