Started up my car the other day and it was running really rough........... took it to my wifes uncle who is a mechanic and had a look. said it appears to be running on only 5 cyl............ checked em out and there is definatley a miss in cyl #1.
as we were only at his house couldnt find out for sure what is causing it.........thought i would throw it up here to get peoples opinions on it..
As far as i can tell i have 4 options as to the cause....
spark plug
coil pack
injectors
or the bad one.......a valve..
the car is running just really rough and bad vibration through the whole car..........any ideas?
https://www.sau.com.au/forums/topic/206474-only-running-on-5-cyl/
firstly try to eliminate all the easy problems first eg spark plugs and test the coils to see if that fixes it.
if it is that then your lucky, if not then you'll have to go about replacing the more expensive bits.
so try the easy bits first
swap spark plugs with another cylinder.. this will cheak sparkies..
pull the coil out and start it without a spark plug.. if it sparks.. its not the coil packs
injectors.. use a multimeter.. get a workshop manual.. and cheak the voltage/amprage
cross all these off.. and then double cheak them.. then find 3 other ways to cheak each part.. then find other things that can cause it.. and as a VERY last thing assume a valve.. because valves dont just shit themselfs for no reason.. broken valves are caused from wrong calculations when shaveing blocks/heads.. or extended periods of very very poor timing settings..
see what can cause damage valves and then diagnose those and see if it realy does lead to broken valves..
An easy way is to go down to repco or supercheap and get a compression tester.. it fits where your spark plug goes.. you disconnect the battery and then crank the engine.. and it will regester the max PSI on a guage.. this can determin if there is a leak within the chamber. Do this to all 6 cyl's
BOM!.. gosh im good! :whistling:
lol... Im really proud of that!
and sorry to complicate things.. but gaskets can also cause a los of preassure that can manifest or appear as though a cylinder has dropped..
keep us updated so we can help
Edited by GTS4WD
I feel sorry for GTS4WD. All that effort and a mechanic takes over... :ermm:
agreed. there wasn't any real point in asking the forum in the end, ask the mechanic next time :D
So your saying I dont do as good of a job as a mechanic!?! :P
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
