Hey its me again !
I've heard a lot of exhaust problems and all
but i've heard people putting on a silencer and increase power...
I would like to know if anyone here who can quote me a price on a silencer
and where to get them?
Overall, any information on silencers (like if its a universal adaptor) would be great
david
https://www.sau.com.au/forums/topic/206658-silencer/
silencer doesn't increase power.
to put it simply, it'll make an overly large diameter exhaust smaller, i.e. 3" and by doing so increases the volumetric vacuum efficiency of said large exhaust.
most exhausts have to be designed with a silencer.
as for quotes, search the regular online performance shops or head down/call your local exhaust shop.
simple.
/thread to be closed.
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3655215
any place that sells mufflers should have them
they are just a piece of pipe with a sort of round dish that bolt straight into the tip of your cannon muffler
you could get the same effect by getting a flat bit of metal the same size as your muffler tip and drilling a hole in the middle of it. then stuff that into you exhaust..
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3655524
wouldnt worry about a silencer....
get an Oval style resonator put in....
will make it quieter, and give it a gruntier sound....
i originally had a 4inch canon put on a 2.25inch exhaust...was running crap
put the silencer on, ran better...
took the silencer off and added an oval resonator, runs better
next, reducing cannon size, keeping piping and resonator...run best..... :)
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3662516
Cuz you got an N/A car, if you put a 3" exahaust / large cannon muffler, you are loosing back pressure volumetric efficiency. By placing the Silencer in, it narrows the In-pipe of your cannon muffler and reduces the size back down to say 2.5" so your not loosing back pressure volumetric efficiency. = Get you power back up.
Silencers, pretty much a metal cylender, goto any exhaust place and they can make / measure one up for you. Or if you bought an aftermarket exhaust, they usualy come with a silencer.
Edited by Eug
correct terminology
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3669290
i have made the appropriate edits in the above post...
it's funny seeing people who know about something without even knowing the correct terminology or even how to spell. hardly makes the information provided seem credible and will only confuse others from my personal point of view.
while this isn't a direct attack on (00)SKYLINE(00) i am merely using him/her as an example to inform others of the correct wording for future reference, more accurate search results and to prevent confusion with new forum members.
cheers
eug
p.s. - the thread will remain open, but the ideology that a silencer will increase power is not entirely correct. in the instance of an excessively large exhaust you will regain the response lost by installing a silencer into said excessively large exhaust. however on a well suited exhaust with efficient volumetric vacuum/scavenging characteristics (2.0" ~ 2.5") installing a silencer will more than likely create back pressure, and thus decreasing the efficiency of the exhaust.
just remember, back pressure is bad - you do not want it. increasing the volumetric efficiency of an exhaust will decrease back pressure.
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3669388
Just want to make sure, but if you have a set inlet size (say 2.5") the muffler tip size only affects the noise that comes out of your car and has nothing to do with performance or any other factor, correct?
This is of course assuming the the muffler tip is at least 2.5" too.
Thanks.
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3670512
Hi guys, i had a silencer on my 6" cannon with a 4" tip
I use it for the longer trips at higher speeds to keen the fiance from getting a headache!!!
Ive stopped using it now though because it left a whole lot of black exhaust crap around the exhaust edge and silencer.
It looks good though, but id only ever use it as a show accesory, not much else.
You can kinda see the silencer in this pic
http://s21.photobucket.com/albums/b258/EMZ...nt=IMG_2706.jpg
And compaired to without
http://s21.photobucket.com/albums/b258/EMZ...nt=IMG_2523.jpg
EMZ
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3694910
Damn, as you know I put 2.5" system recently,,,but it wasnt with a oval resonator.........its with a donut resonator, so when i run without a silencer it was sooooo loud, So i put the silencer back in so it runs smooth.........
So if i put a oval resonator instead of a hotdog one, i wont need to put a silnecer and create any back pressure ya?
Just thinking, do I have to get rid of the donut one to replace oval one or can I just add oval one with hotdog one (keep both)?
Cheers
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3703245
that was way too confusing... oval donut oval donut oval donut.
to be honest, just do what you think feels right. there is no perfect setup, not unless you want to invest the time and money on bench flow tests and buying different exhausts. it's alot of R&D involved.
the 2.25" - 2.50" is a general rule of thumb!
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3703570
hehehe :woot: my bad.......just thought that using a oval resonator will reduce noise better than hotdog resonator, thats all.
Cheers :D
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3706648
Got a question regarding this.
I know that if you put a 3" exhaust system on a N/A car it will lose power as it doesn't have enough volumetric efficiency.
I'm getting a cannon put onto my car this Friday, nfi what size it is, I'll post a pic up to help. But anyway, the pipe from the flange back towards the cannon is the same as stock size and the cannon increases in size a fair bit. Will I lose power from this?
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3714684
I have a silencer in mine. With the silencer out, there is a huge increase in noise, and a slightly noticable gain in power. I keep the silencer in for the road, but take it out for skid pan days etc. Car sounds way more angry and aggressive with the silencer out. :(
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3724616
Yes i pulled mine perm out but in the back of the car..... so if i do get pulled over b4 i get a yellow i can knock it back in and bult it in and start it up and the police should be kewl with it.
Even so ur car can go up to nine decibel in sound and with it out i do not think it hits this and just drive like a sane person if u floor it police will grab u on the flooring and will not worry about the sound.
HaPpY Driving people
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3754608
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
