Motorplex meet.
  • Replies 233
Originally posted by deesh
how hard was that to fit? I know someone on this forum is interested in the kit, but ill end up having to help him fit it, not naming any names.
Id like to know what im getting myself into if i agree to help.
Some people have no skills... you know who you are.
eh? I have crazee mad l33t skillz! Just no tools.
lol :lol:
At least I'm not a Captain Bolt Stripper, eh Boozstor :uh-huh:
I'll see if theres any stock of KCA349 in Perth, expect a call from me If there is :cool:
Daneesh, are u going down on sunday??? are u running, i'm trying to get my hands on a 2nd hand safc, from what i heard from Joey, u had alot of sucees with urs, so ii'm keen to get 1 in and tuned, think i will get a power increase????
thinking of running the quarter tho...... i av no idea how to lauch ma car so I DUNO
I'll be there to spectate, for sure. If I can get new rubber and the kca349 kit before Sunday, then I'll run as well.
2 thumbs up for the s-afc. Sorting out af ratios and confusing the ecu into not knocking back timing did wonders for me. 253rwhp at Barrys dyno.
Come down on Sunday, it should be great. Launching at the track is much like launching on the street - hold revs, side step clutch at 2nd orange light and hold on for the ride.
Originally posted by adam 32
is this anyones first time at the drags apart from me? i need someone els to make a fool of themselves bogging down off the line with me!!
I wouldn't worry about that Adam. The first time I went I was a little bit nervous but no one really cares if you make a mistake. No one has made a perfect launch everytime.
My first run I thought I had gone over the staging line so i chucked it in reverse and as soon as i did that the green light went..... wasnt my best run :cool:
Ben
Yep this is gonna be my first run :uh-huh:
So get ready for some serious insanity launching:burnout:
Im sure ill bogg it down good. Joe u can use a spare helmet i might be able to find but if not im sure someone will let you borrow theirs for a run or 2. :cool:
Guest KILLER-T
Good news all going well tomorrow i will be racing on sunday:burnout: :burnout: and if you want a lift joe give me a call and i will pick you up on the way.This is going to be lots of fun i have been hanging out to run my car since i had the new turbo fitted :uh-huh:
Called up Westshock this morning and reserved the last set of kca349 they had. Picked it up this afternoon and looks like word is getting around, cause someone else wanted a set after I'd reserved.
Organized for a pair of yoko A539 to be fitted on Friday. They really should be going on the front, but I may put them on the back for couple of days so I can loose the top skin at the drags.
So, looks like I definantly will be going. :burnout:
KILLER- T, good to hear your able to run. Lets hope the traction gods are smiling on you :)
Guys/Gals
You want to launch about 500RPM higher than FULL BOOST RPM. This is what ive been told and seems affective.
When wheels start to spin back revs off slightly then all the way to redline, Snap 2nd gear and hold on thru gears hehehe
Higher boost/power newbies to motorplex 2nd gear snap seems to launch you into whatever direction you are pointing ie if back wheels kick out u may need to straighten up or u will go offcourse :-)
I find the track is a fair bit grippier than black asphalt
IMPORTANT. Most slightly modded skylines will do a +160kmhr terminal speed which is just over 3rd gear redline so make sure u take 3rd to the end
:burnout: :burnout: :burnout:
Does anyone agree with this
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
