  • Replies 159
Does anyone know if R32's would have different bolt hole positions for the doors? my kit doesnt line up properly. its about 3.5mm out. so at the moment i have my car ripped apart in the shed completely undrivable until i put everything back on.
We are dealing with this issue and in talks with the manufacturer.
No ones had problems installing on a series 1 R33 have they? I just got a new job so i'm hoping i'll be able to buy a lambo door kit in a month or 2.
Never had problems with the R33 and we have one on our own R33.
Hoping within the next couple of months, depends on interest really. Only had 15 views on ebay for the R33 GTST/GTR gear surrounds which is pretty poor.
interested in gauge mount carbon fibre dash thingy
how much is this and were do i get it??
does it fit over the top of your dash or how does it mount exactly?
interested on lambo doors if they are as easy as it seems,
cheers
Edited by SJR
tyson no special tools needed. standard sockets, elbow grease, screw drivers, big ass hammer and some masking tape.
Hahah sweet thanks. Do you know where i could buy elbow grease from? Just joking. Are your doors still doing fine? I'm really tempted to buy these lambo doors in a week or two but i wanna be sure that i'm not gonna screw up my car lol.
Oh also did you take off your front wheels when you put the lambo door kit on your car?
why would you need to take of your front wheel for ? LOLL
Coz it said so in the guide on the website? So i was just wondering since i really can't be bothered taking off my front wheel if its not neccessary.
I didnt really follow the guide on the website it was pretty straight forward...so initally i hadnt taken off the front wheel.
Lets just say my wing man came very close to losing his finger.
You would be surprised how much the front/side gaurds actually go underneath and back along the body of the car. It makes it ALOT easier to take the gaurds off if you remove the wheels.
Heck i took headlights out as well the more space the less likely u are to scratch other pannels!
Also my doors are pretty fine, had to give em a grease last week to stop the creaks but otherwise they are fine :)
Thanks Chris.
Kietz don't call me stupid, read the guide before you start saying shit. First you were all like "why would you have to take the front wheel off?? LOL" as though it was the dumbest idea in the world then you called me stupid when i said coz its in the guide. You are just making yourself look like a retard. The guide said it was OPTIONAL, if it said i MUST take the front wheel off then i wouldn't of asked now would I?
than there u go why would u ask a stupid question ofcourse u gonna get a stupid answer LOL! its optional to take of ur wheel or not so why u ask a silly question like that for!
Sorry are you trying to be funny or are u actually slow??? im somewhat confused now
You seem to be neglecting one small point! the answer to the question. You seem to think its a dumb question therefor has a dumb answer. Really your just lame computer guy with nothing better to do.
Tysons question may not have been worded the best. But clearly it ment a few things. is it essential to take the wheel off? why? whats the difference in doing with it on or off.
As i mentioned alot easier if u spend 5minutes taking the wheel off first
cheers
The dash pod isn`t ready yet as the fitment was wrong when we tried the sample. I think the mould warped in tranit to Asia and ruined the sample. Have to start again on this one.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
