  • Replies 108
Originally posted by Moanie
A six pack of beer does not count ;)
I'm gonna starve myself anyway :)  Just so you won't have any reason to walk away :)
ohhh how sweet..
u know as long as u got that turbo of ure's... this little black duck aint goign no where ;)
see i can be nice!!
Guest skylinegrrl.
Originally posted by SW20-GT
why are you going to sell it????
im not definate yet. but i'm thinkin sumthin TT. rx7 or supra. i'll c.
yeh. statistically thers more guys than girls wit imports. but teh whole chick wit hot import thing hasnt grown into the community yet. its not new. but its not old either. giv it time to expand.
a question tho. 4 u boys. when u c a chick in a hot mod'ed car. R u
1) less likely 2 drag her
2) pretty sure that its not her car
3) pretty sure she wont drive the car as good as u can if u were on it.
&. everythin's a stereotype. chicks /w hot cars being HOT is a stereotype.
so ok there are some girls with imports in syd!!!!!!
what about us guys on the coast?
i have no prob with cruizin around to c the quality that is out there in syd but seriously there is a big lack of quality chicz driving quality imports up this way........
i can think of 1 that drives a line, and there was the girl in the cordia(not really quality) on the cruise on sunday but thats about it.
:P
oh well spose i should stop bitchn now
:burnout:
Guest skylinegrrl.
when you say QUALITY. are you refering to the CHIC or the CAR?
Hrmmm....seeing as noones answering these questions, let me answer on behalf of the guys on this forum...
1) No way would i drag her...i know my ass is gonna be owned and i don't want my mates to tease me for the rest of eternity about it
2) Can't be her car! its hotter than mine...i'd be too jealous...its easier thinking the guy in her life owns the car...much better for my ego
3) I know she can drive it better...thus i know she'll beat me...and thus theres no way i'll drag her....(refer to question 1)
:bahaha:
1. I will drag her. Equal opportunity peoples!! LOL
2. Id try find out if it is her car, lookin for a g/f with a import! hahaha:D
3. hmmmmm, we would have to go to a track and find out! Perhaps a date????!!! hahaha
1. I would probably be trying to talk to her and would miss the lights altogether and thus have my arse smoked... but would still chase her to try and find out if she is on the forums!!
2. Would try to find out who owns the car after finding out about the forums.
3. Well I guess we would have to take that to the track and even then it might not be fair... she could have driven more laps around the track than me!!!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
