I don't recommend it, but those cheap HID kits will get what you want.
Plug and play.
When looking for which globe to get, 4300k, 6000k, etc, go for 4300k. Any more and you're doing it for the looks. 4300k is the brightest of all and gives a white light, should be same as sun light colour.
Edit: Either that or just spend money on some quality globes from the Philips range. They're not HID so it won't produce a shitty cut off line and hot spots (which is a good thing).
Edited by adam-__-
Go for 5K lites in h1 size and you'll be laughing... very bright (close to hid intensity without the flare and glare of course)... if you don't want to go hid, these are the go!
Most of the ones on ebay will last you 8-12 month which is pretty good....
Those cheap ebay globes you've posted up will do nothing except give lower light output due to the extra blue paint they throw on the globes to produce the colour.
Go for something from the Philips range. May be more expensive, but will be worth it. It'll give a brighter light and last longer than those posted.
I don't want you to get those HID kits so I'm not even gonna tell you the price of them or which globe type you'll need. :P
I picked up some Raybrig halogen globes while in Japan.And can honestly say they are the best halogen globes ive ever used.Bright light and has the white blue tinge to them.
99% of the china "HID" style globes give crappy light output.
Raybrig 4400k FTW!
I am using these now, have last over 12 months and looks awesome... it's very bright white light with only a dash of blue which makes it look awesome but visibility is awesome too...
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...N:IT&ih=021
how come the one u sent the link of along with the ones i sent link off, dont need kits? and the more expensive ones do? is that cuz the HID kits are old technology?
The kit ones are the ACTUAL HID globes. Those other ones are just 'wannabe' ones. haha. HID kits are new-ish technology. It's just that they're not suited to our headlights so it's not good to use them.
When you see "kit" then it's the actual HID version, ones that say "HID" but don't have anything to say about "kit" would be just normal halogen globes which are trying to look like HID globes (colour wise).
hid's were the best mod i ever put on my car, how come none of u guys like them, they make the road so much clearer and make the car look better at night
Installing HID globes in a car's headlight which was designed for halogen globes will cause the light output to glare, hotspot and blind oncoming drivers. It's better for you, but bad for the oncoming drivers. Oh and I forgot to mention that they're illegal, but then what isn't these days.
Hey i was wondering if any1 could help me. my series II R33 hasnt got the best lighting at night, im running calibre xenon blue from supercheap auto on low and hi beams. would phillips diamond vision be better?? or chromium white?? was wondering if i should Readjust the angle of my headlights aswell....any1 no how 2 do so or have a good link on what screws do what??
cheers
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
