Hi guys,
I'm in the middle of deciding how to upgrade my gtst's performance, and number of options have come up over the last few months...currently i am chasing a fmic before anything else happens, but after that, i dunno wut i could do to the car and would like a few ideas.
right now the car has a hi-flowed T03/T04 hybrid turbo, complete turbo back exhaust, pod filter, stock cooler, S-AFC, EVC 3 boost controller.
It managed to make 200rwkw at 15psi of boost after tuning the S-AFC (comes to abt 270rwhp).
Could anyone gimme an idea of wut sort of power this car could make once a fmic is installed? The car would probably be running at 10psi most of the time, or maybe even stock...I just want to know wut sorta power I would be making. If it feels sufficient, I may call it quits as far as performance goes, and concentrate on the suspension and brakes like a good boy.
Hypothetically, a budget of around 4k-5k would be do-able after the fmic is installed...would take a while, but do-able...would like to know wut could be done with this money.
I have more in-depth questions, but will post them once opinions have been made regarding these questions first.
Please feel free to talk at length, then everyone can benefit from the know-how
thanks,
Zak
https://www.sau.com.au/forums/topic/20695-performance-upgrade-questions/
Hi Nrage33, I would suggest a GTR fuel pump as the next mod as you are getting close to the limit of the GTST fuel pump. Then a standard R32/33 GTR intercooler (good up to 300 rwkw) usually gives a 20 rwkw increase over a standard R32/33 GTST intercooler. I would then suggest an adjustable exhaust camshaft pulley. That should give you 230 to 240 rwkw which is pretty close to what the standard internals will handle.
Hope that helps
sydneykid,
thanks for the info...what does an adjustable exhaust camshaft pulley do anyway?
I'll definitely look into the fuel pump tho, I can feel these current fuel pumps I have are near their end...
If i wanted to reinforce the internals, what exactly would I need to do?
Guest RedLineGTR
2.5 lit should be fine depends on how much power you are after..and if you are going over 240rwkw then probably some mild internal work...but after that you can push it even more depeneds on how much money it comes too in the end...remember tuning and dyno time as an extra cost..
This is what happens when you are making 240rwkw with an RB25 and then slap a RB30E bottom end in there.
http://www.skylinesaustralia.com/forums/at...=&postid=433625
Due to the head flow charastics the final power is still roughly the same.
I guess the saying still applies.
There's no replacement for displacement. :burnout:
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
