Hey,
These are the photos you asked me for earlier, sorry you can't see a damn thing, all the wiring is hidden. The only two wires coming from the distributor go to + and - on the coil. There's no ballast resistor, no vacuum advance... nothing! There is a one additional wire going to the + and one to the -, but I couldn't trace where they originate from.
Hope it's of some use anyway.
Cheers,
D
Thanks guys and Mag 86 I believe your right. The good news is I'm picking up a 280zx dizzy on sat morn,rushing it to the mechanic who i hope is going to have it running same day.Thanks for the effort on the pics Drew, and guess what I saw just around the corner in someones back yard? a 210 4 door. I knocked but nobody home so I slipped down the side to see if it was man or auto.Turns out to be man but fully gutted inside. I'll go back tomorrow and ask what's happening with it. I'd really like to manualise my coupe and grab the bumpers. Ill let you know the story.
Oddly there IS a vacuum advance on my dizzy, but it has been left disconnected - no hose. It came back that way from the auto electrician and I didn't notice till later. Maybe it doesn't work, or they deemed it superfluous, or maybe, just maybe, they happen to be a pack of 2-bit retards! Still, I'm none too fazed and aren't going to get nasty about it; the car is going just fine without it. I gave it a run with the vacuum advanced connected to the manifold and I couldn't pick any difference. Maybe it is cactus and no-one ever mentioned it.
Keep me posted about that 4 door. I've always got room for another 4 door. Even one without bumpers!
Drew, spoke to the young lady at the house tonight,her boyfriend was given it but has sold it to a mate who's turning it into a rally car. She's going to get him to ring me regarding the bumper. Hopefully he don't need bumpers for what he's doing.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
