I build an rb26 for 600whp-440wkw..
My specs
HKS Pistons, Rods, Cams(272-9,32), gears, timing belt
Nismo oil pump with all mods for oil problems (external oil return,tomei oil galley)
Single turbo HKS T04Z 0.81 with divided manifold (XS Power) and with XS Power external 50mm wastegate
All studs ARP, All gaskets TOMEI.
A little ported head..
All bearings ACL
800cc sard injectors stock fuel rail
1 intank walbro and 2 external walbro with surge tank
600x300x100mm fmic intercooler
3" exhaust
I need splitfire coils? What the problem if I don't buy them?
The same questions for uprated ignitor?
And for damper pulley?
I'm just using splitfires (no upgraded ignitor) in my RB28 with 522whp. Maybe just get your std coils checked out and try them. There's nothing to loose really and then if you need the splitfires etc buy them then.
I've got an ATI one on mine to be safe. Not sure what the std one is good for.
Still using the std ignitor. Have a search for testing the coilpacks. It's been covered before.......somewhere.
Edited by jonn
When your doing a power run, the tuner will know the coil packs are having troubles keeping up by how the engine miss's.
if you run the car up on the dyno and make power with no issues you know they are OK.
I think i remember beer baron saying that on the HKS drag car they still run the stock coil packs, they are better then split fires when they are in good condition.
So take your chances, they might turn out to be all ok.
arent those xs power items china stuff? You already got the good gear...might as well fork out the extra for the name brand? I got splitfires and the hks twim amplifer..also running ati balancer
Yes china stuff.. but xs wastegate I read that work fine... and the xs manifold I will improve its strenth with brackets! Again I read for this manifold for rb26 signle that it is good quality and they don't broke! I think that also the 6boost is china stuff same with xspower but as I read many people use it!
6boost isnt china made you idiot. Its made locally here in AUS.
Have you even researched where its made? And by whom?
Doesnt sound like it at all
The poor man pays twice, i suspect days it will also happen in this case
I would change the balancer on any built rb26 motor as I have seen a lot of factory items flogged out. I believe that this is probably the reason behind a lot of broken oil pumps. I build a lot of sr20's and everyone one of those Ive seen with a broken oil pump has had one of those GFB solid pulleys fitted.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
