mine is sorta resting on the bottom of the tank which makes it louder, when the fuel gets hot on a hot day you can really hear it outside the car, buzzing its ass off. it'll be fine mate. FWIW the walbro pumps are quieter but who cares when you got a decent exhaust anyway
https://www.sau.com.au/forums/topic/207176-bosch-040/#findComment-3665270
it is pretty loud, but not unbearable.
yea they are supposedly rated to 400hp. they are only loud when priming, and i can only just hear it on idle when i blip the throttle when the stereo is off.
but overall it gives great bang for buck.
5/5
but 3/5 for its power capability
https://www.sau.com.au/forums/topic/207176-bosch-040/#findComment-3665277
Ive had issues with mine, and am taking it back to the workshop to try a different pump as i have had starting issues ever since installing the 040. it holds fuel pressure fine though and has no trouble holding sub 12 afr's on full boost, but starting the car sometimes sucks!
https://www.sau.com.au/forums/topic/207176-bosch-040/#findComment-3665281
If i can only 'just' hear it at idle i can live with that. Anything more though and i'd probably get pissd.
Hey! I hope i don't get starting issues. My mate has one and recommends it, never had starting issues. Did you install it yourself and stuff it up? Hehe
https://www.sau.com.au/forums/topic/207176-bosch-040/#findComment-3665298
yea mate....seriously all u will hear is a buzz and hiss on priming.
and other than that u cant hear it.
i only heard it because i was REALLY listening for it.
but its not like 90db or anything..
no one will be like , WTF IS WRONG WITH YOUR CAR DUDE.
lol
Edited by r33cruiser
https://www.sau.com.au/forums/topic/207176-bosch-040/#findComment-3665306
I got one for my R32 GTR, but swapped it and another $200 for a sard. The 040 didnt fit into the nicely engineered cradle, so i would have lost fuel pickup depth and sound/vibration isolation if i had used it. The car already surges on 1/4 tank at the track... For GTS-T YMMV.
https://www.sau.com.au/forums/topic/207176-bosch-040/#findComment-3667029
Bought it today from CRD. Will be fitting it over the weekend. I'll post comments if anything interesting happens.
I agree with you, the gtst will never surge like a GTR so i think it should be fine. Plus my car won't see the track that much.
The nismo 275lph pump comes with its own cradle and touches the very bottom of the tank.
It shits all over any bosch.
Oh, and its quiet - I can't hear it at all.
You're right but for half the price i think it's a good compromise.
na didn't install myself had it done professionally by a workshop then checked by another workshop as i was sceptical of the install and they have said it was installed fine
Ok dude, you're a mix between paranoid and OCD. :P
Nismo bolt ins, are for gurls :banana: lol
For the cost of em, you'd want them to be quiet (undoubtedly they use a fuel resistant insulation, like factory)
Lol. I'll agree with that one, only cause it makes me look tougher ;)
https://www.sau.com.au/forums/topic/207176-bosch-040/#findComment-3667558
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
