Originally posted by Low-Ki
if i may add just one thing, 400r was the best skyline ever built, it had the lloks and the power and the most exclusive rights to ownership,
:werd:
but i wouldmind the new motor in an older skyline, the new shape just doesn't do anything for me, the r33 has the fattest shape ever and i dont think anything will ever surpass that.
:( right on!:P
  • Replies 173
The pics of the car are *NOT* anything to get excited about. Basically, they're just pics of the Skyline coupe, with CG ehancements taken from the 1:5 scale clay model which, DOES NOT look like the GT-R Concept.
What is good amongst them though, is the diagrams of the Motor-assisted Turbo's, pics of the engine itself, and a pic of the new RX-7!
Receiving now... My cable connection has been slowed to 28.8 so it's rediculously slow. I'll be back in half hour when they're done then It'll only take me a couple of mins to resize. If intensevil has posted his by the time they finish receiving then it's all good :D
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
