Nissan Skyline Silhouette R31
S3 Silhouette 1990
RB25det from s1 r33 skyline
Excellent condition
144,000 kms on car
5 speed manual
White, colour coded bumpers
Canberra ACT
Engineered for RB20det (paperwork supplied)
Sep 2008 rego
$5000
Skylines Australia dyno day:
153rwkw untuned, easy for 200rwkw with a tune, up the boost & bit bigger injectors.
Sheet provided
Contact Shane for info 0421 374 379
Minispooled Diff, 4 wheel disc brakes, tow bar, boost guage, turbo timer, hr31 cluster & grille, big radiator & twin thermo fans, 3inch dump pipe to 2.5 inch cat and pipe, King springs, central locking (needs wiring fixed)
Newly added: Cannon 2.5 to 4 inch, sway bar & exhaust rubbers, spark plugs 0.8mm gap, vacuum hoses, fuel & oil filters, Big 800 by 300 by 75mm Front mounted intercooler with chrome piping, colour coded bumpers, new cat gaskets, new exhaust manifold studs bolts & gasket fitted.
Extras: R32 blown turbo, 3inch dump pipe, R33 BOV, 2 small lengths intercooler pipe bends, new break pads, r31 sway bar.
Edited by whiteRB25det
https://www.sau.com.au/forums/topic/207295-car-sold-please-delete/
  • 1 month later...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
