i have a fair idea of what i actually need but if like to hear some suggestions n see if on the right track
for mods list please check my for sale add.
question,,, wats the difference between caster rods n tension rods?
also are these brand stuff any good?
http://www.nissansilvia.com/forums/index.p...howtopic=244517
or should i pay the extra 100-150 per item for jap branded stuff?
many thanks
For more lock, buy some tie rod spacers, worth about $20
For less body roll, buy some upgraded swaybars, should set you back around $450 for front and rear bars.
For more steering response, increase your caster, adjustable caster rods will do this, they can be had for $220-$400 depending on quality.
Oh, and tension rod = caster rod = radius rod.
There are more ways of going about these things, but I think these are the cheapest and simplest, so would be where I would start.
yeah it is better to get some decent castor rods (CUSCO, URAS ect as they have dust boots and far better rose joints $339 pair lifetime warranty) the xtra lock spacers from uras are about 19 bucks and the whole arm if you want to upgrade are 239pair.
caster rods n tension rods are the same shit
and there nothing wrong with the d-project castor rods still as strong and does the job
but you will get what you pay for
as for more lock as said already tie rod spacers,
although from what ive heard the 32s streering racks are shit
and you get shit all lock from them, as well as that you can only go so far
befor your wheel started rubbing on your castor rods
first i would get r33 lca which are longer then the r32, cheap upgrade that will help stop your wheel from touching
your castor rods so you can get more lock not to mention more camber
then a S14 steering rack give much more lock then the r32s, and ive heard they fit into the r32s (not 100%sure)
Don't cheap out on GOOD front tyres.
Talk to Mo about swaybars if hes still at GT.. last time I asked he could do them for about $400 for whiteline adj 24mm/27mm
btw that picture of deans face is almost hypnotising :)
I don't think that swapping the steering racks would have any benefit unless you planned on doing work on the inner guards to give more clearance. With the stock rack and tie rod spacers, I have had a couple of scrubbing problems with the front inner guards.
btw that picture of deans face is almost hypnotising :P
hahah dean ftl
yeah he no longer works there, but that sidney kid bloke sells em for 220 each i think it was so meh, its only 40 extra...
IMO the right anti roll bars are essential and for those you need to talk to SK - Gary .
Also I'll be blunt , I think you can buy much better than the Jap name brand stuff namely the Whitline/Bilstein kit parts .
No guess work involved , buy bolt align handle .
Cheers .
  • 3 weeks later...
I found that installing adjustable solid tie rod ends gave me better steering responce (that is tighter and more lock at full lock)
As well as adjustable solid castor rods.
Have had the ones from justjap for about 2 years with two track days and never had a problem.
Those sway bars will make a big difference!!
Which brand? JJR or the other jap brand just jap supply?
PS sway bars coming tomorrow :D
Rose jointed tie rod ends will only give you better steering response if your old ones are well and truely rooted. They can not give you more lock, you need different tie rods for that, namely different rack ends to add lock.
The adjustable tie rod ends are adjustable for bumpsteer, they can help when your car is too low and has too much bumpsteer, but the better solution is to raise the car up so the rest of your geometry isn't screwed either.
I also found polyurithane bushes help steering responce. The stiffer bushes stop some of the flex in the OEM rubber ones, which, especially in a car as old as a 32, are likely to be perished and soft as.
just a thought.
ok guys
tien hr coilovers
front sway bar set to soft on front
rear sway bar set to hard on rear
rear cradel bushes set to 'overall performance'
front tire pressure set to 37psi
rear tire pressure set to 45psi
nismo 2 way
car handels like a fkn dream!
butttttttt sucks when u try go full lock (which is poor) especially trying to scando, steering response is slow :down:
but these 2 will hopefully be changed soon
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
