i have a fair idea of what i actually need but if like to hear some suggestions n see if on the right track
for mods list please check my for sale add.
question,,, wats the difference between caster rods n tension rods?
also are these brand stuff any good?
http://www.nissansilvia.com/forums/index.p...howtopic=244517
or should i pay the extra 100-150 per item for jap branded stuff?
many thanks
For more lock, buy some tie rod spacers, worth about $20
For less body roll, buy some upgraded swaybars, should set you back around $450 for front and rear bars.
For more steering response, increase your caster, adjustable caster rods will do this, they can be had for $220-$400 depending on quality.
Oh, and tension rod = caster rod = radius rod.
There are more ways of going about these things, but I think these are the cheapest and simplest, so would be where I would start.
yeah it is better to get some decent castor rods (CUSCO, URAS ect as they have dust boots and far better rose joints $339 pair lifetime warranty) the xtra lock spacers from uras are about 19 bucks and the whole arm if you want to upgrade are 239pair.
caster rods n tension rods are the same shit
and there nothing wrong with the d-project castor rods still as strong and does the job
but you will get what you pay for
as for more lock as said already tie rod spacers,
although from what ive heard the 32s streering racks are shit
and you get shit all lock from them, as well as that you can only go so far
befor your wheel started rubbing on your castor rods
first i would get r33 lca which are longer then the r32, cheap upgrade that will help stop your wheel from touching
your castor rods so you can get more lock not to mention more camber
then a S14 steering rack give much more lock then the r32s, and ive heard they fit into the r32s (not 100%sure)
Don't cheap out on GOOD front tyres.
Talk to Mo about swaybars if hes still at GT.. last time I asked he could do them for about $400 for whiteline adj 24mm/27mm
btw that picture of deans face is almost hypnotising :)
I don't think that swapping the steering racks would have any benefit unless you planned on doing work on the inner guards to give more clearance. With the stock rack and tie rod spacers, I have had a couple of scrubbing problems with the front inner guards.
btw that picture of deans face is almost hypnotising :P
hahah dean ftl
yeah he no longer works there, but that sidney kid bloke sells em for 220 each i think it was so meh, its only 40 extra...
IMO the right anti roll bars are essential and for those you need to talk to SK - Gary .
Also I'll be blunt , I think you can buy much better than the Jap name brand stuff namely the Whitline/Bilstein kit parts .
No guess work involved , buy bolt align handle .
Cheers .
  • 3 weeks later...
I found that installing adjustable solid tie rod ends gave me better steering responce (that is tighter and more lock at full lock)
As well as adjustable solid castor rods.
Have had the ones from justjap for about 2 years with two track days and never had a problem.
Those sway bars will make a big difference!!
Which brand? JJR or the other jap brand just jap supply?
PS sway bars coming tomorrow :D
Rose jointed tie rod ends will only give you better steering response if your old ones are well and truely rooted. They can not give you more lock, you need different tie rods for that, namely different rack ends to add lock.
The adjustable tie rod ends are adjustable for bumpsteer, they can help when your car is too low and has too much bumpsteer, but the better solution is to raise the car up so the rest of your geometry isn't screwed either.
I also found polyurithane bushes help steering responce. The stiffer bushes stop some of the flex in the OEM rubber ones, which, especially in a car as old as a 32, are likely to be perished and soft as.
just a thought.
ok guys
tien hr coilovers
front sway bar set to soft on front
rear sway bar set to hard on rear
rear cradel bushes set to 'overall performance'
front tire pressure set to 37psi
rear tire pressure set to 45psi
nismo 2 way
car handels like a fkn dream!
butttttttt sucks when u try go full lock (which is poor) especially trying to scando, steering response is slow :down:
but these 2 will hopefully be changed soon
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
