Well I'm going to be need more fuel for my new setup this year. However I really don't want to run a surge tank it seems like a hassle and not entirely needed at least from what I think.... could be wrong. I've been searching for a few hours now and am having trouble finding someone whose running their fuel pump(s) like this.
Using my currently intank walbro 255 as the lift pump, but not using a surge, and off that same feed line, running the 044 bosch then to the fuel filter, the fuel rail, into the FPR and back into the tank for return. Any issues with this setup type of setup? heres a shitty drawing I did in paint for it.
thanks.
That setup should be fine.
You haven't mentioned what fuel tank your putting it in. Most Skylines seem to get away without a surge tank, if they're 1/3 full.
044 is rated at 600hp, which is about 350rwkw.
In reality, a tank and some line wont cost that much extra if you fit it under the car. Once you go in the boot, you'll have to use hardline or teflon braid to limit fuel weepage and cabin smell.
Edited by GeeTR
Its actually in an s-13 chassis, using the stock fuel tank. The rear of the car is gutted, and car has a 6 point cage it in. The car is daily driven so I do place items in the hatch (one reason I don't want a surge tank).
I'm under some time constraints currently to getting the car finished and moved out so a surge tank can always be an option for under the car at a later point.
I'm aware of the 044's output however are you saying that because the power outputs don't add to each other? I understand that there will be loses with this setup so it will never see the full potential of both pumps, but it should be able to make over 600hp since the walbro is aiding it as well?
S13 chassis - nice, I almost bought a 180 with a RB20 in it 3y ago.
No sorry - I was just rambling off the output, as you hadn't mentioned a turbo, or power goal :)
Correct, having the ass of the 044 fed a positive pressure will undoubtedly help it reach its "on paper" spec.
180 or Silvia? As if 180, the boot isn't sealed from the cabin, so you cant legally fit a s.tank setup in there ne way. you'd have to enclose all the gear in a box, or just stick it under the car. My vote is for a carefully designed under floor setup. It means you can use ordinary EFI hose with worm clamps, and don't need to be fussed with fancy stuff to prevent smell.
Lol, well I'm from the states, and around here theres no emissions testing or anything, so no worries. Its a s-13 hatch with chuki front end. I think for the moment since its cool to run the pump like that, I'll just use my stock lines and nipple adapters.
Setup is 2.7 liter stroker with forgies of course, 8.5 to 1, 35r T4 hot sided tons of other goodies too much to list. Looking to make close to 500rwhp with pump gas here. I shall see. This setup should be plenty for that.
The walbro wont be "aiding" the bosch at all, the bosch flows a truckload more so its pointless having the walbro there at all IMO.
good point, I know in fluid systems like for water plants and such, running pumps in parallel doesn't allow them to flow their max do to line sizing and so forth.. I shall see, basically the walbro will just be hanging out then if that ends up being the case. I'll know more when I'm making pulls and watching my fuel pressure.
I tried the exact same thing. The 044 was cavitating with that setup, it just couldn't get enough fuel in.
If you want to run an external pump then add a surge tank with a decent size feed into the back of the 044, otherwise get an 040 and replace the in tank walbro and run one pump.
...the bosch flows a truckload more...
The Bosch does indeed, but the Walbro's issue is suppling flow at high pressures, which isn't occurring here as its not pushing onto a FPR and making 60psi, its pushing into the back of the intake of another pump; Its pushing into negative pressure area. hence Id think It'd be fine.
Don't get me wrong, im not a fan of the setup either, but I know ppl that do run it like that, and its fine. The things you can get away with are amazing.
Dave, were the two pumps close to together?
PS: Nice sounding setup Cory, but wtf's a Chucki?
Edited by GeeTR
the 044 was in the back corner of the boot walbro in the stock location in the tank, so maybe 800mm between them by the time the hose wound it's way into the boot.
to be honest i think the 044 just didn't like a 5/16 feed line as i had the same problem when i initially installed the surge tank and maintained the same 5/16 fitting on the inlet of the 044. I upsized to 3/8 (i think) or maybe 1/2inch, can't remember, and the problem went away.
Its not feeding a negative pressure area at all. Thats why you need a lift pump to feed it. The old VL turbo pumps needed a lift pump due to this same reason.
If it did produce a neg area behind the feed there would be no need for a surge tank or a lift pump as the 044 would generate its own fuel supply.
Dave is correct the 044 will always cavitate when being feed by something like a walbro with a 5/16ths line. A 3/8ths feed should be fine for that pump. You really need to do it properly and run a surge tank gravity feeding into the 044. Or use an intank 040 and all your problems are covered with an intank solution.
Dave is correct the 044 will always cavitate when being feed by something like a Walbro with a 5/16ths line. A 3/8ths feed should be fine for that pump. You really need to do it properly and run a surge tank gravity feeding into the 044. Or use an intank 040 and all your problems are covered with an intank solution.
Confusions :( My point was that a Walbro, pushing against no restriction (or think of it, as having its output sucked from it by the 044) should keep up with a 044.
An 044 (roughly 040 sized i thought) into a S13 tank while not technically hard, isnt a simple affair I'v found; which is why people supplement the setup with a external 044, simply using the smaller Walbro to force feed it (and give it that head of pressure your talking about)
My 044 will be mounted in my engine bay, so there will basically be the length of the car's distance between the two. I think your pumps might have been too close together? OR maybe it was too small of a line. In theory you would think the fuel would be sucked through the walbro more with the 044 since they are hooked to the same line it would be aiding.. Maybe I'll call bosch tomorrow or a company that sells these pumps and uses them to see what they think.
GeeTR this is a chuki front end and my car...
The Japanese I do believe, and its KA24 :(.
We call them a Onevia in Aus. The opposite of Sileighty. :D
Thus your Chuki is a 180sx in Japan, with a 2.4L making 240, sucks to be a yank I guess :D
Edited by Wheezy
chuki is an sr 180 front end, zenki is the ca 180 front end, as far as Aussies and Japanese are concerned.
type x front ends have a different name again, but i can't remember it as i've only seen it mentioned once.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
