If you want to do any street driving I would recommend going for a built jatco re4r03a as you still retain the overdrive but they are expensive compared to something like a C4.
The overdrive would be nice for street driving, granted, as would the bigger and stronger components of the RE403 over the Skyline 401 but like you said, they're much more expensive to build to take the power being suggested than an equivalent C4 or TH400 which are known quantities where spares are very readily available.
If it came to it you could get Mike from MV to put a JATCO together as he does some good work at reasonable prices but the standard Jap boxes are too hit and miss when you start leaning on them hard. I'd stick with something that you absolutely KNOW will do the job time after time.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3677753
cool thanks heaps...
ive heard the jatco's arent as strong???im not going anything nissan i have big plans for future and dont want to change but i still know next to nothing about auto's...
What about powerglide???
Any other choices or c4 is def the pic???
You could quite easily adapt a Turbo 400 or Powerglide to your engine but it's all about what you want to do with it. Having a third ratio is good for cars with narrow power bands. What does your car weight and how does it make its power?
The C4 is a relatively light and small (narrow) box as well so it's a good option in a drag car where every pound counts.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3683003
A built C4 is a strong box but dont under estimate the re4r03a as testing in the states indicates that these boxes will survive 1000hp and beyond.
The question is for how long, mate. Dom Rigoli had an RE401A in his 1000hp WRX for ages but how often was it pulled out and at least checked each meeting? It's a lighter car than ours too so who knows. 1000hp is one thing but in a 3300lb car it's a whole other story. C4's and Glides can hold that power in a 3500lb car all day so I know what I'd prefer.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3686510
The problem with the subaru re4r01a is that the output shaft is very small compared to say a skyline re4r01a and half the size of the re4r03a. Once they upgraded the output shaft size to powerglide spline size they had no more issues with breaking output shafts. I will be testing the limits of the re4r03a boxes soon. We have kept the shafts standard (other than heat treating) to see what weak links show up. These are larger than a v8 glide so any problems should be fixable using higher grade steel.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3686587
Lost them there Smiley
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3709416
  • 1 month later...
probably worth a mention that with the rather large turbo you are running and depending on how
tight the converter is you will probably have to give the big girl a sniff to persuade it to come up on the brake. A small dry shot will do it, something like 50hp. Unless you want to be on the start line staaling it up while the other car crosses the finish line like most VLs you see
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3810001
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
