  • Replies 112
So it's Friday arvo nearly time to knock off and I was bored as hell so I went through the thread and compiled everyone into an easy to read list.
SAU ID PSN ID
Sl!m - VertexR32
Gts30t - Shodaddy
mattis96 - qik33
trism - t_r_i_s_m
r33cruiser - a_BFG
smurf80 - smurf80
MADGT4 - madsammy
OZ_Pomy - iLEC
Kozeyekan - Kozeyekan
thirty four - reggin_au
Goziiraaa!! - Bourne01
[Michael] - kaido
GoldZilla - GoldZilla
kralster - MrCharismaAUS
Magic - Blaq-Magic
typevu - typevu
Bumblebee- GT2-KLR
GeeTR - rkaid
S13Deviat - Andominated
YLD-CHLD - YLDCHLD
Krimz - krimzn
=premo= - incorrect_method
LEANBAC - LEANBAC
dezz - dezzmang
AMS - oconnorams
Dush - Dush
MaTBoY - matboy
atang - atang34
TiTAN - sau-TITAN
SKYLVIA - WildWarriorBizz
Kaz180 - Kaz180
ABuSD - KellyNUTS
krzysiu - KrzysiuR33
BAMR33 - bamr33
gt_relish - Gonzarelli
Frunknmont- fl1pp3
PSICO - McWhizzle
PWND - foamer
joe26f - Stagezilla
jeffboyracer -sjhanan
bigjimmystyle- Bigjimmystyle85
W0rp3D -warped
EVL-R33 -WarMachine
writeoff -writeoff3
muirsky -muirsk
hkspwr -hkspwr115
Ry34 - Ry34
omy-33 ashdroid
TheProDaniel- TheProDaniel69
Howie -Howiefied
hanyou -hanyou8
nismo_GTS -Ants84
Sl!m if you want seeing as you are a mod and the thread starter you can put this in the first post.
Edited by Frunknmont
  • 1 month later...
  • 1 month later...
Good work on the list Adam!
I'm still playing COD4 but am SICK of getting shafted because of the lag. I'll try coordinate a time for a SAU grudge match. Look for invitations in your inbox.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
