im going to try a different fuel i think
ive just filled up with Mobil Synergy 8000 or whatever it is, we will see how that goes
also, cos its been so hot lately, ive been using my A/C heaps
im going to see if out of a tank i dont use it at all and see what difference that makes
"Yah bro!" :)
Its mm of mercury...
Trust
Me
I have a HKS Boost Gauge
The pointer goes only up to where I have circled, which I believe is +0.7 Bar = 10.1 Psi.
Just help me clarify this cuz Iam interested to know...
Thanks!
Also, don't bother saying how many KMs you get to a tank. The best way to work it out is:
1. Fill up to a full tank
2. Reset trip meter
3. Drive
4. Fill up, note how many litres it takes
5. Do this calc: Litres divided by KMs ... then times that figure by 100 = Litres per 100 KMs
The reason this is a better comparison is that one mans "empty" is different to another persons. For example, I normally get 320kms out of a tank... but I never take mine to RIGHT on the E mark, and I put 42-46L in it.... so around 13 - 14 L per 100kms, which is around normal for a mildly modified GTR IMO.
yeah thats why i said removing the restrictor makes you run 14.7 psi
not saying that is a good idea
what im saying is that the gauge is in mmHG not bar
7 mmHg = 1 bar
May i ask, where is the restrictor that you remove to get full boost?
  • 1 year later...
my 32gtr is pullin 400km's for full tank. all i had done was injectors cleaned, changed air filters, o2's,
i give it a fair bit of push around suburbs.
but yer my injector is now leaking out fuel i assume this time round i wont be gettin 400k's.. what is it i need to replace .. O-rings for it? and is it hard to replace?
i just got a power fc installed + car tuned.
driving sensibly im now getting around 420 to a full tank round town.
i've been giving it a hard time this tank and it looks like it will hopefully still be around the 320 - 350 mark.
car is almost stock - 222rwkw @ 12 psi.
hope this helps.
also, check your comp - is it standard? my old cpu was the main cause of my previous poor economy (around 300 to a full tank barely hitting boost).
Edited by KR4-GTR
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
