well got my new exedy single plate heavy duty fitted by ice performance today and WOW is all i can say, its soft, but nice and touchy, perfect for quick launches, doesnt ride too easy which is good, will stop me ****ing it up :( and wasn't too bad during peak hour traffic on the way home, would recommend it to anyone who isnt going too far with power like me but needs something more than the stocker... btw my stocker was nice nj burned when i looked at it today hehehe but yer im really happy with it, next stop, powerfc and electronic boost which will be fitted and tuned tomorrow so will post my dyno results, then next week ill get tmy c's short shifter which i just ordered so now hopefully i can break some 13s at calder :P:D:D but we'll see...
https://www.sau.com.au/forums/topic/20791-new-clutch-in-verdict/
yeh i got mine done @ C&D Motorworks in Sunshine. They're a performance place also. Lots modified Rex's & imports in there all the time. I also got a quote for $650 for my timing belt from Ice but got it done @ C&D for $280 (genuine Nissan belt)
Mind u Leewah from Ice has always been very helpful and informative whenever I've ever asked for something. I know my car is going to go down to Ice when I need to get some internal mods done in about 11months time ;)
$650 ? maybe that was a special type of belt ?... oh well im planning on doing all those maintenance things myself anyways... i might get some of ice's cam gears coz they are very nice and also well priced, see how they go, might help to get my over 200rwkw with stock turbz ;)
nope just the Nissan belt. They said it cost so much cause they have to take the radiator and all the belts off as well to get to the timing belt. ah well.
btw What as your car running rwkw wise when we went on the cruise down to Great Ocean Road?
Unfortunately its pretty similar to the Daikan Exedy. Exedy kit is about $420 and stock is about $350?
The exedy is very daily drive able (hell I drive from Sunbury>City almost every day)
Originally posted by Timmy G
how much does a clutch similar to the factory r33 gtst cost?
umm at the gor it was stock LOL so about 130rwkw or whatever it is, with pod, zorst, safc & 10psi, front mount i managed to pull 182rwkw, now i have the powerfc and electronic boost so will be interesting to see what it pulls
timmyg, the exedy clutch i just got feels softer than my stocker did, its just a lot more touvhy and 'shorter' contact space if u get what i mean, it thros the power to thew road much better than the stock and doesnt huirt your left legf after long drives, i drove to ice and back and i live the opposite side of town and my legs were fine
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
