HI guys, I will be getting my HKS GT2835 Pro S soon, just wondering, for the people that have it, does it still have that nice spool jet sound that the standard turbo provides?
You'd think it would be louder since it's a bigger turbo, am I correct???
I would hate to have it installed and it makes minimal spool noise, Id be heart broken! lol :)
cheers
And what about the flutter, I love my flutter... Will the flutter be louder than the standard turbz? I should be, bigger turbo yeh?
I would suggest a Recirculating BOV, as it will make your turbo last longer.
Also, sounds like you want attention?
Cops will love you.
This one is better:
http://users.on.net/sau/pacey.avi
Port shrouded is a "windowed" compressor cover
Looks like this:
Lol, still dont get what you mean, that just looks like a normal turbo to be that dont have a filter and not connected to the cooler...
ps. your vid didnt work :)
Cops will love you.
F#$k recuirculating, I just wanna hear that biatch flutter.... Took of the plumb back stocky BOV, flutters real good.
So will the HKS GT2835 Pro S Flutter louder?
ANd also, will the HKS GT2835 Pro S turbz maker the spool sound yours did?
CHeers
spool will be louder than stock as the wheel is steel, your pushing much more air, and running a pod (no doubt)
all these things will make it a fair bit louder.
My old GT30 sounded like an aircraft once i plumbed the gate up :)
i've got a link for my vid somewhere, but you cant hear a lot over screamer pipes :)
This one is better:
Looks like this:
Im about to bolt on one of those,external gate though :)
CHeers
You dont want it to "flutter" your turbo wont last long.
lancers have mad flutterz and spool noise. Buy a lancer and its a straight fit for a triton diesel turbo to go on. Will be faster, be more cuztom, and flutter way more.
You dont deserve a nissan
Vid please! What were the specs of that motor?
ok... found it Click me!!!
GT30, 45mm gate, Nismo (factory GTS-R) manifold, RB25 (built), factory head/cams :down:
24psi/104 sunoco, thats the major stuff anyhow
GT3040?
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
