GCG Hiflow Turbo Excellent condition, $SOLD for $1200 Inc Postage
with 3" Front / Dump Pipe $150
Removed from 1997 R33 GTS-T
http://www.gcg.com.au/Catalogue_Menus/Upgr...pgrade_gtst.htm
Pick up in Brisbane Southside or Can Post
Edited by Brokenz
pictures with gcg plates?
how many kms?
any shaft play etc?
what kind of power did it make? what boost?
willing to seperate?
reason for selling?
im interested but dont need the dump/front pipe
cheers
$1350 without the dump pipe. It was only running 220kw as it was road use only. Came off a Damaged 97 R33 GTS-T RB25det. I bought the damaged car off another Skylines Australia Member and was going to fit the turbo to my R33 4 door but I am putting that car up for sale. The turbo is in excellent condition. Almost like new. Good for someone as they are usually $1950 + you have to send your turbo according to the GCG website. I will put up photos tonight.
Last owner only bought the car in November 2007 so he does not know when it was done. Car came in with 72000km in 2006 and now has 87000km so lets say it was done in the last 15000km and within the last 2 years.
r33dyno.pdf
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
