Nathan Weissel, winner of the 2007 NSW Drift Series and 8th overall in the National Drift Series, has joined forces with Federal Tyres as his major sponsor to contend the 2008 series.
After competing using Federal Tyres in his early days of drifting, why has Nathan switched back to Federal Tyres?
“I tried other brands but the Federal tyres are still my favourite,” said Weissel, “they give me the best level of grip and control and do not suffer with heat like other brands.”
Nathan will use Federal 595 Ultra High Performance tyres on his Nissan Skyline R32, with 235 / 40 ZR18 on the front and 265 / 35 ZR18 on the rear.
“Federal Tyres engineered the 595 Competition Series tyre to handle the abuse of drifting,” explained Brett Quodling from National Tyre Wholesalers. “The 595 provides responsive performance at high speeds and exceptional adhesion and control when needed while withstanding excess heat from wheel spin.”
Nathan will compete using his new Federal Tyres at the first round of the 2008 Drift Australia Series at Symmons Plains Raceway in Tasmania this weekend.
Special thanks go also to ACL Race Bearings, Wolf ECU's, Motul Oils, Stamford Wheels, GCG Turbo's and Sign Design for their support.
Media contacts:
Nathan Weissel
P: O2 Auto Sports - (02) 4423 0977
National Tyre Wholesalers (Australia)
Brett Quodling
P: 1800 050 060
E: [email protected]
www.federaltyres.com.au
www.driftaustralia.com.au
post-16772-1204201119_thumb.jpg post-16772-1204201142_thumb.jpg post-16772-1204201161_thumb.jpg post-16772-1204201190_thumb.jpg
  • 6 months later...
Pity you can't buy those tyres anywhere, only the lower load rated and speed rated tyres at local shops, with what the Federal website indicates is a different tread wear as well. (Well in 17's anyway)
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
