chubs, you're going down.......my new bigger wheels will give me road contact, my bodykit will save me some weight and my big ass wing will give me more downforce................and I wouldn't be surprised if I score a slower time than before LOL
I should be faster in theory..........but we all know, a lot of things work well in theory.... like communism.
Most likely I'll be heading down early in the morning e.g. 5:30 or 6 so anyone wanting to meet up, arrange something.
James,
I'm in Liverpool area, so let me know what time you're passing through and I'll meet you on the Hume somewhere (crossraods servo), or if there's a few of us, we can organise a place.
  • Replies 202
James,
just registered need to pay now to confirm, iam 5 min from crossroads...wouldnt mind tagging along than driving down myself.
She isnt going dude. She's got a broken toe and she is soft :)
and on crutches! and soft!
did I mention soft?
well ,she is :action-smiley-069:
Hai Georgie if you are reading this!!
(perhaps she should sign up here!)
did I mention soft?
well ,she is :whistling:
quoted for proof of bad mouthing. Now, some one get Georgie to sign up and read this and own chubbs with a bitch slap
did I mention soft?
Oh man she's soft, thats like the softest thing that every softed!
Come on Georgie, fire up!!!!
ok so...............let organise a meet up time and location.
Whats a good place to meet up?
Last time for the SAU event we met in the parking lot of Bunnings at Crossroads.
(just off the highway)
Otherwise, is that servo still there after the cross roads on the left before you get on the freeway towards Campbeltown
(I've put the points on the map below)
http://maps.google.com/maps/ms?ie=UTF8&amp...065832&z=14
It's an hour and half from campbelltown with no stops once you get on the freeway, so i'd suggest if you're leaving liverpool around 6:00 you should be ok if you have a fuel stop at the BP on the way in.
Factor in another half hour for tyre changing and the like on arrival if you are a chance of being in group 1....
trip down is 2 hours so 8-8:30 arrival means around 6 am leave from sydney.
so - 5:30-6 meet up time
6 am leave from crossroad
I'm around teh corner, so will be there 1/4 to 6 at the latest.
What!! Did you say she isnt going dude? Just because she's got a broken toe? She is soft :blink:
did I mention soft?
well ,she is :banana:
Speaking of quotes :banana: (you can pay me later Chubbs)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
