Make: R32 GTR Skyline
Model: 1989
Milage: 136,000kms
Transmission: TRUST 6 speed gearbox
Colour: Silver
Complied? Yes
RWC supplied? Will arrange for QLD buyer
Currently registered? Yes
Price: $42,000 but willing to negotiate with serious buyer
Contact: PM or phone 0438797053 for any serious inquiries or to arrange an inspection
Comments / Modifications:The motors has just been rebuilt ~2000kms ago with a new N1 RB26 block, a list of modifications is included below. This is driven daily and has no problems in traffic or on long roadtrips (I drove up from Melbourne in it). Selling because i need a family car.
Images: See below, more available upon request. Can also provide in-car video footage for a non-local buyer.
UNDER THE HOOD
Engine:
New N1 RB26 Block
1997 R33 GTR RB26 Head.
Engine Improvements:
HKS 86mm forged pistons/ring set
TOMEI forged conrods
New R33 GTR crank
NISMO main and conrod bearings
HKS Step 2 camshafts IN272 EX264
HKS adjustable camshaft gears
N1 water pump
JUN oil pump
Metal head gasket
TOMEI head bolt washers
TOMEI oil pan baffle
TOMEI valve springs
HKS valve system seal
NISMO engine mounts
Earls 32 stage oil cooler
KBC dual core radiator
Hi Octane Racing radiator air guide
APEXi reserve tank
CUSCO oil catch can
Spitfire coil packs
NGK spark plugs
Induction:
Trust GReddy T88-33D turbo
HKS front mount intercooler
HKS blow off valve
Twin HKS pod filters
2 x RB25 AFMs
Fuel System:
TOMEI dual feed fuel rail
Denso 720cc injectors
Sard RJ fuel pressure regulator
Custom 2L surge tank
Intake pick-up fuel pump
2 x Bosch Motorsport 600hp external fuel pumps
Engine Management:
APEXi Power FC with hand controller
Exhaust:
3” dump pipe with heat wrap
3” mandrel bent exhaust
APEXi cannon muffler
Trust wastegate
Trust exhaust manifold with heat wrap
DRIVELINE
OS GIKEN triple plate clutch
NISMO transmission mount
2wd/4wd in-car switch
BRAKES/SUSPENSION
Global 324mm front brake rotor kit
Gallop HICAS cancel rod
Gallop pillar tension rod
Gallop rear member
TEIN HR adjustable coilovers
CUSCO 5mm short front upper arms
D-Project adjustable rear upper arms
NISMO steering rack mount
Front strut brace
WHEELS/TYRES
R33 GTR 17”x9” rims
Kumho Ecsta 255/40R17 front tyres
Toyo T1-S 265/40R17 rear tyres
INTERIOR
Sports Z 320km/h speedo
Momo Race steering wheel
Trust gear knob
Leather gear knob and handbrake boots
Half roll cage – bolt in
Defi Tacho with shift light
Defi boost gauge
Defi water temp gauge
Defi oil temp gauge
Defi oil pressure gauge
Defi fuel pressure gauge
EXTERIOR
Bomex front bar
N1 rear boot lip
N1 Headlights
D.Speed clear indicators
Tinted windows
PERFORMANCE
Max power output:
482rwkw @ 20psi on pump fuel
Best ¼ mile ET:
10.8sec@128mph in full street trim
SERIOUS AND GENUINE ENQUIRIES ONLY. FOR MORE INFORMATION OR TO ORGANISE AN INSPECTION PLEASE CONTACT TRISTAN 0438797053.
Edited by Chunners
https://www.sau.com.au/forums/topic/208254-fs-gojira-480rwkw-r32-gtr-skyline/
  • Replies 55
wow... what a machine. I thought it should be under 10s car
10.8 in street trim is pretty fkn fast........ you take out the rear seats, air con, etc. and put a set of big slicks on it, your looking at breaking 10 seconds imo.
The car is fast but there is still more in it. Set it up for drags and the numbers will drop abit.
I have seen this car and it sounds and looks amazing.. The plates say it all. Nothing would come close to beating it on the streets up here.
Good luck with the sale mate. I only wish i had the money lol..
Is the trust gear box straight cut or helical? When was it put into the car? Did you buy it new or used?
Who built the car?
The gearbox has straight cut gears and was fitted in Japan. I was told by the supplier that it had done 1000kms when i purchased the car.
Racepace Motorsport in Melbourne and X-Treme Motorsport in Townsville are the 2 workshops that have helped me build my car. Racepace built the new motor but was installed and tuned by X-Treme.
Hope that helps, any more questions just ask.
Cheers
I'm with FONEY on this one, have seen this car in action with the old engine set up and it was mighty impressive then. Its an absolute weapon, highly recommend this car
Saw this car out on a local cruise a few days ago, very clean and serious street car. Mature driver too.... hehe, was infront of him (grey 32 gtr parked next to you at bp) on a nice straight road subtly trying to coax him to hit it in order to make my decision of going single or twin, besides the point. He didn't want to play ball .. :cool:
Good luck with the sale.
  • 3 weeks later...
lol at last post.
but man seriously congrats on the car, its an absolute beast. just look at it
but i want that front bar so bad.
wanna swap for a genuine GTR bar b4 u sell it lol.
GL with sale man and get a 4 door 34 for family car then RB26 it lol
Hi Mate
what gear was the car dyno"d in ?
Thanx
It is normally dyno'd in 5th gear, but the other night it was done in 4th (still made 480rwkw on 20-21psi).
25k
+ your car?
Quick update: Just got 4 brand new tyres 255/40R17 (not yet fitted) and some new SARD 1000cc injectors. Injectors have been installed and the fuel maps were adjusted on the dyno. Since the injectors are no longer maxing out, i will increase the boost and get a full tune in the next week or so. Will post new dyno sheets when i get them.
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
