Hey all,
Got a set of Volk GT-N's (2 piece rims) but I want to add more dish and widen them to fit bigger tyres. Does anyone know where to go to get this done??
Any ideas would be appreicated.
Cheers,
Johno
same thing i wanna do.
http://www.raceengineering.com.au/mods.htm <-- unsure of state
i no so one or 2 in vic and qld but dat wudnt help u.
just google "rim widening nsw"
but shudnt this be in fabrication section?
sum dude up in qld is getting his srr widened for more dish $230 each wheel, they cut the face off and weld a section from a donor rim :down:
altho much cheaper if u can find alloy(most are steel) rim barrels
http://www.raceengineering.com.au/wheels.htm
the rim barrel's or the cut nd shut?
i'd say that they shud be strong enuff as ppl get their rims widened for racing, sprint car, tarmac etc, same shud apply to the barrels.
falling apart and you would have a big reason to crack the shits, get ur money back and sue them, as thats pretty dangerous
unsure of warranty, see other examples that the company ur choosing has made, customer cars etc, and their reputation
Edited by Dan_J
Hmm f**k doing that option to a Volk Rim. I was thinking more of the lines of undoing the two piece rim, and moving the centre piece back to give it more dish and more of a negative offset. This even possible or am i dreaming? Because if something like that was only a few hundred bucks id be up for it.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
