At the risk of being flamed here's my car on 20's for show
more pics: http://www.mswt.com.au/gallery.asp?thisind...E+NISSAN+R%2D33
its good for show. But not the best fo handling and ride comfort. Hence why I have the below lmgt4's as my daily's :laugh:
  • Replies 143
nah, i chose suspension integrity lol
dropping ur car to the floor is so try hard, biggest rice mod i can think of.
If you insist. :yes:;)
My car is very low (maybe 2 inches off the dec), but most people are surprised what kind of suspension setup I have in it and it's hasnt been thrown together, it was all picked to perform.
Silk Road / Section RMA-8 coilovers (10kg/8kg prog rate with helper spring) with PROPER 8 point dampner adj.
S13 Hubs, Knuckles and stub axles on standard R31 LCA's
R32 front calipers and R33 Non turbo rotors
VS commodore rear calipers
Bendix ultimate front pads, Bendix advance handbrake pads
Cusco tower bar
3rds Productions Rose Jointed Adj. Castor Arms
Whiteline F+R sway bars
Noltec Adj. panhard rod
Driftshop S13 roll centre adjusters
Ikeya Formula steering rack spacers
Alloy steering bush
Urethane gearbox mount
Super-pro bushing all through car (Trailing arms/swaybar links)
7 point rollcage with rear tower bar built in
Ill also be putting a R32 steering rack in in the near future to get even better steering
Ive owned a R32, a S5 and 2 x S3 RX7's a 180 SX, a S3 R31 import (IRS) and another Aus Del 31, and out of all of them, my 31 has been the best performer. Sit's flat, and is very responsive. Has great grip (10 inch wide rears help) but is VERY easy to coax into a slide. I raced Karts when I was younger, and my dad has raced since he was very young (both cars and Bikes) so it's not like we stick china coilovers in and think it's the greatest thing ever.
Im not going to jump into the SK groupie bashing like everyone else does on NS.com, as Ive been a 33 with a full SK track setup, and it was brilliant...
But maybe commenting on a cars suspension integrity should be kept to yourself. Ill have to take you for a skid lol.... on the track of course.
Edited by R31 drift pig
Do you have any side-on pics?
Have to agree though. Definatley managed to pull 20's off. Look really good wiht the paintwork. Me personally Id lower it a tiny bit more, but you'd probably kiss the kit goodbye in a week LOL
What colour is that BTW?
Thanks
They pegasus rims. No mods to fit, but they rub on the inner guards so might remove them.
The colour is Mercedes Cubanite silver (more a champaign)
I'll dump it if I ever enter it in a show but won't go lower than this for every day.
pm me if you want anymore pics :cool:
its good for show. But not the best fo handling and ride comfort. Hence why I have the below lmgt4's as my daily's :cheers:
Those 20s look awesome,what body kit is that on your car?
you see now his daily wheels are absolutely sex! thats exactly how a skyline is meant to look
really good job on your 33!
chrome 20's belong on some gangstas 4x4
If you insist. :cheers::thumbsup:
Cusco tower bar
Alloy steering bush
haha yeh, im running SK's GB, but ill be the first to point out its not perfect. but i have to say im very impressed with how it performs, looking at 3kg spring rates, you would expect it to roll around a fair bit, but it just doesnt, it sits as flat as most coilovers ive driven on, and the same as mates with cheap coilover kits such as ISC and HSD's with 8/7kg springs, yet without the shit dampening.
dropping the car ridiculously low is pretty bad, i mean id only call it a real ricey mod if your doing it for looks, if your doing it for performance, well, i think youd be hard pressed to prove that point when every bit on information available in credible articles tells u otherwise. but if it works then great, i just think people often confuse a lack of traction with being good for drift, i see a lot of people in KE70's and R31's dropping the car on their arse and running 175/60's and sliding all over the place and then wondering why they cant qualify in comps.
not having a go, i just personally like to relate proven settings and information towards racing etc to drift as well. it comes down to preference in the end.
the daily's look so much better, as much as for some reason im skeptical they are GT4's. seems in ur thread there is similar doubt. only reason i have doubt is the first thing that struck me was the angle and concaveness of the rims, for the offset they are the usually pretty much straight, it is only the wheels with around +22 or less that feature a noticeable concave appearance. also with that concave shape, with a GT4 it is a more smooth curve, rather than a straight spoke pointing out then sharply coming back in, similar to what is seen with Koya drift teks, URAS NS-01's, DT-05's etc.
also the spoke shape is different to what id expect, the spoke is more angled in, from wide at the middle, to wider going towards the rim/barrel, the GT4 is usually more straight and overall wider.
haha well seems everyones the expert on lmgt4's on here without ever owning any. think ill be taking some pics of the badging on the inside soon.
the fronts are flatter. the rears are 9.5 wide. hence the more agressive angle on the spokes. it doesnt just depend on offset.
My silk roads are some of the best coilovers to come out of japan (even though they were probably made in taiwan or some shit), they dampner adj. ACUUALLY works, and is a simple 8 point, not a fully sick 36 billionty way. You can seriously feel the difference between point 4 and point 8.... Ive had Tein, JIC, HKS, and custom made, and these by fare are the best.
The ride height was also a by-product of changing to a S13 setup. A S13 coilover at full extension ie. wound to max height will actually drop a 31 30 - 40 mm..... My Front coilovers are only down about half way, and are fully captive even at full extension, and my rears are a little lower. The kit also makes the car seem lower than what It actually is too.
I dont have a massive lack of traction, the thing actually sticks like shit to a blanket. It was built as a circuit car, then modded to suit drift (alignment changes and spring dampner settings).
I run 225/45 R18's on my 10's, so enough tyre getting down. Id love to go wider when I fit my TD06 in the next few weeks, but I simply dont have the room underneath those guard lips.
All of this being said, the 31 is still a largely untested car, and I dont think Ive realised it's full potential.
Yet the one vital thing, which no matter how good the car is, will make it or break it - The Driver. :D
And as a side note, I run 205/50 R15's on my KE70 LOL..... Be even better when I change to my 15 x 8 -4 wheels. But with a 4K 1300cc powerhouse,under the bonnet, I aint qualifying for anything LOL.
:D
It's nice not to have a screaming match like on NS.com about suspension for once.
And Liquid Ice, I had another look at those pics, I really like those wheels. You'd be one of the only ones to pull of 20's in my eyes.
And look how quick this shit is gonna catch on.... the japs are sticking 19's and 20's on Z33's/V35's/R35's all over japan, soon enough they'll be everywhere.
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
