Well i rarely go to brissy, well into the heart anyway. Closest i get to brissy most times is springwood macca's or abit further up sometimes when we get in amongst the street crew on the highway on the weekend evenings but that hasnt happened for a while. Trying to stay off the freeway now. Espesh wen i pick up the new machine
  • Replies 57
pain in the butt if ya ask me. But u would be used to it and probably know it like your palm knows your roger. As i know the goldy streets fairly well. But still more back roads to learn but thats all in time. Who's 33's was there at that cruize u just had?? Im after a suspension package for mine when i get it something to sit it a fraction lower but not too low
well i got wheels for me 33 already. There 18x8's. Avanti deathmesh they are. 235/40/18'sfor tread so a suspension package to suit the loot shouldnt be to hard aye. Plus the occasional swap back to the stock 16's on the rear for a bizzare unknown reason( secrets )
so far im thinking 3 inch from the turbo back, high flow cat, small resinator in the middle and a muffler at the back. Been told that will produce some noise with the resinator suppose to take out the supposed drone effect. Got told they can also add the drone so i aint know what to do at this stage but i dont want it to damn loud, would love to have it bulk loud but dont want to be hassled by the cops everytime they pass me
probly round 4inch. Matey i am not 100% sure on the exhaust yet i still have to get some more oppinions and even hear afew different combos before i decide. I just want the increase in power over a cat back system. then a pod filter comes im thinking latest apexi. should be very likeable ride once those options have takin affect
well thats the plan, it wont happen overnight but it will happen and i am positive of that. Its gonna be my pride n joy when i get it. I got to drive the car on saturday for bout 2 hours. Taking it places and getting it checked for big smashes previously and that checked out fine. Took it to the mag shop and stuck the mag beside it. showed my mum n sis. and the rest of the time was out on the road taking it for a strap. Really like the way it drove. Dont get me wrong i didnt nail it everywhere coz i am gonna buy the thing so i didnt wanna cane it to much. Do u got a car>>>?>??
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
