  • Replies 126
hey guys...
since getting my GT-T in xx/12/08 i haven't been on a cruise and really love day cruises...
was wondering if it was possible to list the meet points as i have work on sunday until 3 or so...
would be great to meet at one of the points and have some runs before days end
cheers
andy =)
yeah i think 3pm+ i'll be cruising by myself LOL
oh yeah i mean '07...
man 2008 is driving me crazy, i was at work and signing papers xx/xx/02 for some reason and my colleague was like :cool: 'dude are you alright? it's 2008'
ok, as for the the meet points, its not a long ass cruise, but it does head quite north, cutting it short, City West, Joondalup, Two Rocks with a cruise past lagoon, mindarie then hillaries! its a good run so its well worth it!
sorry if i give late replies but my net has been disconnected so cant get on that often, but will do my beest to check everyday, have not printed maps yet but im onto that tonight...
Good to see alot of interest, cheers guys!
If you don't mind can you email me a copy of the map? I can test run part of the map if you want around my area & I might be able to throw in some ideas :cheers:
[email protected]
Edited by ossie_21
Good to see so many coming so far, and yes, its cool if you dont have a skyline to cruise with us although i would prefer mostly skylines... as for the maps, still not finished, god damn there are alot of streets to consider, lol.
Nathan, i will send you a copy as soon as i have finished bro and im going to need you to print a few for me too(low ink)...lol, and yeah if ya wanna do a test run that cool also, like i said, any input appreciated!
Do you guys think 2pm is too early? any thoughts here would be great, i noticed a few of you cant make it that early so if ya want we can do it a little earlier!
Oh and someone bring a f*$kin ceffy eh, so we can swap for a leg!!
Cheers again guys
Guy
1pm or 2pm is great for me. plenty of sunlight. nice for photos.
i think its best to give out your mobile number 'Jesus' cos some people might come late or get lost or cant follow directions on map. just a suggestion.
it will be awesome to have so many cars on this cruise. photos will turn out awesome.
ok, good idea, my number is 0404726323... maps are done and ready to go!
Nathan i will send you a copy now so you can have a look and then print some off...
Turnout is lookin good guys... again thanks!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
