yeh u could.. just need a topmount manifold and an exhaust shop to extend ur dump pipe.. ull also need new suction pipes made up... honestly way to much work and no benifits i can see? apart from the gains of a stainless manifold (till it cracks) you would also need new oil and water lines as the factory ones wont reach... so im guessing $1000+ to do it with a cheap ebay manifold + fabrication of piping and dump.. i have a 3037 Pro S.. with a Lowmount stainless manifold..
Edited by SLYDA
ohh man.. no way. they wont. they cant.. if they do.. the skyline police (me) will come confiscate the skyline.
Hahahaha! Now that you've said it i bet someone will attempt to do it.
i have a low mount hks gtr-s turbo on my rb25 at the moment and i was wondering if i could make it a high mount
has anyone done or seen this before?
thanks
Complete waste of time.
Why would you possibly want to do this?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
