  • Replies 54
Howdy everyone
I had my first day at a skidpan on sunday, up at gympie as apparently the folks out at mt cotton have over-senitive ears, I had a ball and learnt a thing or two about controlling skids.
It can be found at: http://tinyurl.com/3e4be9
I think the vids cool :P have a look and let me know what you think. Bear in mind it was my first day at the skidpan and id never tried anything remotely like drifts before this.
Regards
Ian
great fun!
do you know NUTS with the green commy ute?
sorta met him on the day, seen his car round heaps but never really met him before. hes a nice guy though. not sure if ian knows him or not?
I met him at a wedding on Sat down on the coast and we somehow got onto skid pans, GTRs etc when he saw mine
argh ok. small world aye. i actually saw his car at a panel shop near my work up here but not sure if he works there or not, or was getting something from there.
it looks and sounds tidy, pity its not Nissan powered to make it real cool... :O
hey mate,
how r ya? yeah the ute was at the panel shop for some rework stuff, got it back yesterday and they did a top job :rant:
also just wondering if these vids are coming along at all?
http://tinyurl.com/3e4be9 ????
thats the GTR tho
na i was wondering if anyone had one of the ute on the motorkana, i think there was a guy out there with a camera taking videos of all the cars
yea we are all still waiting, i havent seen him post in here yet about vids, but ian knows him, and he apparently is away alot working so he might not have been online in a while.
  • 4 weeks later...
heres one from mt cotton, one of the last ones i went to there.
http://www.the sphincter of the universegoat.com/driftzone_skidpan_nov2004.wmv
skidpans are great to learn better control of your car and how it reacts to different situations.
the sideline skidpan days we used to have were always good, particularly the braking exercises and wet surface control exercises. and the sliding of the cars :thumbsup:
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
