Well, the 31 went over the pits again and.... fail. reverse lights didn't work, which is weird cause they did like 1 month ago and it hasn't left the shed. also they didn't even ask about emission's... A#$holes!!! oh well, i can see the light at the end of the tunnel now, and shes f#@ken' bright!
https://www.sau.com.au/forums/topic/209015-epic-fail/
isn't that what you did?
Yes youre right, I did point mine at a sign post (and the sign post lost) but I only cracked the radiator and got a flat tyre... Someone else I know, smashed in the rear quarter panel, bent the boot lid, destroyed the rear bumper and deflated his ego all in the one hit.
By the way didnt you lose it in the wet once and drive over a tree stump?
https://www.sau.com.au/forums/topic/209015-epic-fail/#findComment-3720329
yeah, but james's car was still drivable....
... and that was black ice, not just water on the road.
https://www.sau.com.au/forums/topic/209015-epic-fail/#findComment-3720451
Thats what happens sometimes when you drive your car the way a Skyline is meant to be driven... Not that you would know.
ZING!
That's fine, you can have that one. I don't feel the need to show off when I'm driving.
Edited by Bluprint
https://www.sau.com.au/forums/topic/209015-epic-fail/#findComment-3720986
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
